Hi Dave and all,
Just to add my perspective to this issue.
I fully agree that even as a pure replacement of CA, PVA has a lot of value. Using PVA would be worthwhile even if that was the only thing. Andrew and Kay already outlined the
benefits.
But the benefits do not, and certainly do not need to end there. We at ESS are starting to make a lot of use of the structured data facilities.
For now, the main way to take advantage of them is to use the “group PV” capability. It may seem limited at the first look, but when one dives a bit deeper, they offer quite a
lot:
- The well-proven record types and their functionality can be used as before. They can be templated, initialized, auto-saved,
etc. This has enormous value. No need to re-invent the wheel, and re-debug things that work.
- You can achieve “atomic” processing of several records by using the group feature. Before PVA, to achieve this one needed
to resort to complicated trickery, if it was possible at all. Or bypass the record layer, which led to another set of problems.
- Groups can freely be composed of smaller units, that let you to phase your development without a) having to re-implement
those small units every time and b) being constrained to fixed structures.
- Adhering to normative types, you get a quite good level of interoperability. Normative types are not perfect for all cases
but can express most of the things that are needed. That said, I think there is still need for refinement in the normative types and their definition.
- There are some smaller but important low-hanging fruits that we at ESS are starting to take advantage of. One example is
the User Tag/UTAG that can be used to augment the “classic” timestamp.
I have heard complaints that the group definition syntax is complicated. There may be possibilities to simplify or clarify it, but in the end there is no free lunch.
Just as a remark, the distinction between a (group) PV and a record does not always seem to be clear. I simplify the concept in my head by thinking that the DBR types of CA and
NTypes in PVA are both pre-defined queries to the EPICS database. The difference between them is that with CA, you can only query one database record at a time, with PVA and groups you can extend the query to multiple records.
Now, nothing of the above excludes the possibility of implementing record types that have “native” normative type structures. With those, a number of entirely new capabilities
would become available. There have been activities in this direction, but as this requires substantial groundwork, it has been slow to progress. They would in this case still be records that are defined in the dbd files, can use templating, initialization,
etc.
Then there is of course the possibility to provide structured data without a database, pure custom programming. I personally think that this is of limited use, obscures the system
by hiding logic behind custom implementations and reduces generic applicability. Thus I recommend against it, and have not yet seen a case where the equivalent (or better) could not have been achieved with PV groups.
In my opinion, the record types and providing record instances is still as relevant as it has always been, and for me they are the most powerful features of EPICS.
Best regards,
Timo
Hi Dave,
Yes, PVXS is evolution, not revolution.
That's also why our version numbers jumped from 3.16.x to 7.x back in 2017 — EPICS 7 is the combination of the IOC developments up to Base 3.16.2 with the new PVA protocol from what was then being called EPICS V4. We
realized once V4 was becoming functional that to support our existing users (who were also the employers of most of the core EPICS developers) we had to provide a path for upgrading existing IOCs and control systems, without forcing them to be significantly
rewritten — none of the US DOE sites would have been able to do that. Some work had been done to develop an EPICS V4 IOC (in Java), but it wasn't designed to be backwards-compatible at all and there was no way it could have ever run databases from an existing
V3 IOC.
We are thus being careful to implement changes by evolution instead of revolution, and PVXS was how Michael Davidsaver chose to fix some of the major issues with the architecture and APIs implemented in pvDataCPP and
pvAccessCPP. We haven't decided how and when it might be integrated and included in official EPICS releases, but I'm sure it will happen sometime. Users who rely on on the pvDataCPP and derived APIs will continue to be able to build against and use those libraries,
but there isn't much development being done on them now.
Replacing the GNU make-based build system would be a revolution since there are so many existing IOCs and control systems based on it. We have considered a
proposal to permit builds using meson, and if enough members of the EPICS community express interest and offer to provide long-term effort to maintain an alternative build system we could include one, but removing the existing build system would be hard
to do given all the EPICS installations around the world that have thousands of applications, many with customized Makefiles and local build rules. Maybe AI…
- Andrew
First, thank you everyone for the discussion, it is great to get more context filled in as I learn this stuff.
Andrew, to answer your question, I’m primarily after using the tech with the best future, so I was interested in PVXS just from that perspective. CA is not an issue.
I think my confusion stems mostly from reading the PVXS doc at
https://mdavidsaver.github.io/pvxs/ and noticing that it doesn’t mention DB-style “records” anywhere, but it does give examples of building PV’s programmatically at run-time. This caused me to wonder “is this the new way?”
But from you guys have been saying here, am I right to think that PVXS is mainly a replacement implementation of pvAccessCPP, etc. and is not intended to change things for the basic IOC developer?
[EXTERNAL] – This message is from an external sender
Hi Dave,
When you say PVXS, are you really asking about building IOCs that provide both a Channel Access and PV Access server, or about using the specific PVXS implementation instead of the original
pvAccessCPP?
You don't need PVXS to create IOCs that can talk the PVAccess protocol. PVXS started as a reimplementation of the original C++ client and server code for the PVA protocol but using a better
internal architecture and written in modern C++. It can communicate over IPv6 now, and future releases will be able to use TLS for much improved security, but those won't change the underlying IOC code significantly.
- Andrew
> I’d say the prevalent scenarios would still be IOCs with records, and PVAccess is then
> used just like Channel Access. That’s why we have normative types which mostly mirror
> the DBR_.. types, and clients like CS-Studio that can fairly transparently switch between
> the two protocols.
I guess I’m unsure what the value of PVXS would be in a scenario like that? If you are starting from a normal EPICS IOC project, and adding PVXS, what is PVXS doing for you? You are still
defining your PV’s in terms of records in DB files, etc.
I can see that if you are building an IOC for an embedded architecture, the EPICS build system adds value in being able to handle the different toolchains and build products, etc.
However, at the moment I’m looking at making a soft-IOC (i.e. on intel/amd64 linux), and I’m seeing the opportunity to use a simpler (and contemporary) build system and construct PV’s at run-time,
rather than use DBD/DB which need to be consumed at build.
I’m wondering if this is a compelling idea at all, or a poor idea?
I’d say the prevalent scenarios would still be IOCs with records, and PVAccess is then used just like Channel Access. That’s why we have normative types which mostly mirror the DBR_.. types,
and clients like CS-Studio that can fairly transparently switch between the two protocols.
With PVAccess you do now have the option to use new types. It allows you to transfer site-specific data over the same protocol, but you can’t expect generic widgets to fully understand your
data. That mostly means you need to create both the server and the client, which you can do in python etc.
The new ‘group’ feature does allow you to create custom types by on combining data from records, but for the client side you’re then again on the hook to create for example a python script to
understand that custom data.
So bottom line the goal here should not be that every piece of information now needs to be placed in a newly developed data type with its own custom server and client. On the contrary, the existing
record types, the normative types to read/write them, and generic clients like display managers are meant to fill most of your needs, as was the case with EPICS for the last 30 years.
Going forward, is the philosophy of PVXS to create PV’s programmatically, per the examples (i.e. https://mdavidsaver.github.io/pvxs/example.html#mailbox-server)
Or, is the idea of creating PV’s by providing record definitions and instances via DBD / DB files still intended to be relevant?
One can create a hybrid IOC (https://mdavidsaver.github.io/pvxs/ioc.html)
and still take in DBD/DB files, but this doesn’t seem to really involve PVXS, at least from the developer’s perspective (other than the fact that QSRV2 makes it work).
As always, I may be completely wrong about any of that, so feel free to let me know.
Dave Bracey – Fermilab AD Instrumentation
- Re: PVXS IOC Philosophy Kasemir, Kay via Tech-talk
- PVXS IOC Philosophy Dave Bracey via Tech-talk
- Re: PVXS IOC Philosophy Dave Bracey via Tech-talk
- Re: PVXS IOC Philosophy Johnson, Andrew N. via Tech-talk
Re: PVXS IOC Philosophy Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
Re: Streamdevice - record only completes processing every other activation Zimoch Dirk via Tech-talk
<2024>
2025
2026
<2024>
2025
2026
