Hi Patrick,
It is possible to build and load SNL programs as loadable plugins, we made that possible using the IOC's dlload command back in 3.15. I believe the PSI and ESS methods of building
and booting IOCs use that, but I haven't tried it for a while and I forget what you have to do to create and load the DBD file that tells the IOC where the SNL code is. Someone from one of those EPICS sites may be able to help.
One other possibility you can consider is to build your SNL into a stand-alone program, so that code runs in a completely separate process from the IOC. That decouples the two
and allows you to start and stop them independently, although you do have to ensure that the SNL code is properly written to handle waiting for all its CA connections at startup, and for the PVs going away and coming back when the IOC comes online again.
- Andrew
Complexity comes for free, Simplicity you have to work for.
Hello Jure,
Thanks for your thoughts. It actually have me thinking of ways to change the SNL programs which run based on our configuration. I think I can make that work. The issue I was trying
to get around is it seems the IOC has to be built with knowledge of the SNL programs it can run. That was what I was trying to work around, but if I may be able to build with all of them and just start the ones I need at runtime.
Patrick
Sent: Monday, March 25, 2024 3:23 AM
To: Barrett (US), Patrick E <[email protected]>
Subject: [EXTERNAL] Re: Creating SNL in loadable library
EXT email: be mindful of links/attachments.
Hello Patrick,
While I'm sure it's possible to create loadable plugins from SNL code using some clever tricks, are you sure it's necessary? I don't see much difference if you simply add several different programs to the IOC. In the end, which program
runs is a matter of starting it with the
seq command. In other words, choosing which SNL program to run is a matter of configuration by default.
Best,
Jure
On 3/23/24 03:32, Barrett (US), Patrick E via Tech-talk wrote:
Caution: This email originated from outside of Cosylab.
Hello,
I have an IOC which would load different SNL definitions based on a configuration file. There are some state sets which are the same and some different ones dependent on the configuration.
Has anyone build SNL into libraries which could be dynamically loaded dependent on a configuration, instead of being build into the IOC code directly?
Patrick Barrett
- Re: [EXTERNAL] Re: Creating SNL in loadable library Simon Rose via Tech-talk
- Creating SNL in loadable library Barrett (US), Patrick E via Tech-talk
- RE: [EXTERNAL] Re: Creating SNL in loadable library Barrett (US), Patrick E via Tech-talk
Re: How can I get a PV from an external server from inside a docker container? Dale Cox via Tech-talk
<2024>
2025
2026
<2024>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
