Title: Re: How can I get a PV from an external server from
inside a docker container?
Hey,
Am 26.03.2024 um 21:49 schrieb Érico
Nogueira Rolim:
On 26/03/2024 15:08, Florian
Feldbauer via Tech-talk wrote:
Hey,
just for completeness, if you know the IP addresses of all
your IOCs you can also use the default docker network and set
the Environment variables
EPICS_CA_AUTO_ADDR_LIST no
EPICS_CA_ADDR_LIST <list of all CA server IP addresses>
In this case, the udp broadcast part of CA seems to be
omitted and CA checks the list of IPs directly.
You can also combine them, so EPICS_CA_AUTO_ADDR_LIST=YES so
hosts reachable by broadcast Just Work, and EPICS_CA_ADDR_LIST
for when it isn't an option (this is relevant when outside of
containers as well).
At least this worked in my very first tests with
containerization of our clients (Archiver, Alarm system,
But of course this approach is rather error prone and you need
to change your config every time an IP address changes/is
being added.
If you want to avoid running your IOC with "network_mode:
host", IIRC you can also try adding the broadcast address (last
address of the netmask) of your relevant network interfaces to
EPICS_CA_ADDR_LIST. That way the CA client doesn't need to
enumerate the interfaces in order to find them out, but you also
don't need a static knowledge of all IOC hosts.
but broadcasts do not get forwarded from the virtual docker network
to the physical one, so setting EPICS_CA_ADDR_LIST to the "external"
broadcast address does not work.
On the other hand, this is the only way I know of if running
docker in rootless mode.
Does rootless docker not support setting the network to host
mode? I'd strongly recommend podman for that use case, then.
IMHO it does a much better job at the "rootless container" need
for multiple reasons, including supporting host network mode
without any issues.
Rootless docker (as well as podman according to my tests) do not
support network_mode host or MACVLAN. So the IOC inside the
container is not able to send UDP broadcasts to the external
network.
Cheers,
Florian
Am 26.03.2024 um 09:59 schrieb
Carsten Winkler via Tech-talk:
Hello Dale, hello Florian,
many
thanks for your helpful advises. Now I could solve the
issue simply by adding "network_mode: host" to the service
"epicsbase".
Now
my working docker-compose.yml looks like:
services:
epicsbase:
image: softioc
container_name: epicsbase
volumes:
- ./epicsbase/db:/usr/local/db
working_dir: /usr/local/epics
command:
- /bin/sh
- -c
echo start first Soft IOC
screen -d -m
/usr/local/epics/epics-base/bin/linux-x86_64/softIoc -D
/usr/local/epics/epics-base/dbd/softIoc.dbd -d
/usr/local/db/test.db
tail -f /dev/null # keep alive
network_mode: host
Best
regards
Carsten
--------------------Ursprüngliche
Nachricht--------------------
Von: Carsten Winkler <[email protected]>
Gesendet: Montag 25. März 2024
14:55
An:
[email protected]
Betreff: How can I get a PV from an
external server from inside a docker container?
Hello,
I have 3 SoftIOCs.
1.) local host = 193.100.100.100 with PV:
"local_pv"
2.) external host = 192.200.200.200 with PV:
"external_pv"
3.) docker container on local host with PV:
"docker_pv"
From local host I can read all PVs
(caget local_pv external_pv docker_pv). 👍
From inside the docker container I can read the local_pv
and the docker_pv
but not the external_pv. 🤔
Here is my docker compose
configuration:
services:
epicsbase:
image: softioc
volumes:
command:
- /bin/sh
- -c
screen -d -m
networks:
- ioc-net
networks:
ioc-net:
container I have also already tried
EPICS_CA_AUTO_ADDR_LIST / EPICS_CA_ADDR_LIST.
Unfortunately without success.
With and without these environment variables I only get
the local_pv and the docker_pv.
How can I also read the external_pv
from inside the docker container?
Best regards
Carsten
Ruhr-Universität Bochum
AG der Experimentalphysik I
Dr. Florian Feldbauer
NB 2/131 / Fach 125
Universitätsstr. 150
D-44801 Bochum
Office: NB 2/134
Phone: (+49)234 / 32-23563
Fax: (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
Aviso Legal: Esta mensagem e seus
anexos podem conter informações confidenciais e/ou de uso
restrito. Observe atentamente seu conteúdo e considere
eventual consulta ao remetente antes de copiá-la, divulgá-la
ou distribuí-la. Se você recebeu esta mensagem por engano,
por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its
attachments may contain confidential and/or privileged
information. Observe its content carefully and consider
possible querying to the sender before copying, disclosing
or distributing it. If you have received this email by
mistake, please notify the sender and delete it immediately.
NB 2/131 / Fach 125
D-44801 Bochum
Office: NB 2/134
- Re: How can I get a PV from an external server from inside a docker container? Pete Jemian via Tech-talk
- Re: How can I get a PV from an external server from inside a docker container? Érico Nogueira Rolim via Tech-talk
- How can I get a PV from an external server from inside a docker container? Carsten Winkler via Tech-talk
- Re: How can I get a PV from an external server from inside a docker container? Carsten Winkler via Tech-talk
- Re: How can I get a PV from an external server from inside a docker container? Florian Feldbauer via Tech-talk
<2024>
2025
2026
<2024>
2025
2026
