Hello Core Devs,
I would like to know if you have already considered activating pvAccess
for softIOCs by default.
I would probably adapt the Makefile template and simply copy the section
from the example IOC:
# Link QSRV (pvAccess Server) if available
ifdef EPICS_QSRV_MAJOR_VERSION
_APPNAME__LIBS += qsrv
_APPNAME__LIBS += $(EPICS_BASE_PVA_CORE_LIBS)
_APPNAME__DBD += PVAServerRegister.dbd
_APPNAME__DBD += qsrv.dbd
endif
Ultimately, this should not affect any old system, as pvAccess is only
loaded if it is also present in base?
thanks in advance,
William Kirstaedter
PP&B Computer Support Group
Fritz-Haber-Institut Berlin
smime.p7s
Description: Kryptografische S/MIME-Signatur
- Re: enable pvAccess by default Érico Nogueira Rolim via Tech-talk
- Re: enable pvAccess by default Johnson, Andrew N. via Tech-talk
- Re: enable pvAccess by default Michael Davidsaver via Tech-talk
Re: iocStats Restart IOC PV does not work Michael Davidsaver via Tech-talk
<2024>
2025
2026
Re: PVAccess EPICS environment variables Michael Davidsaver via Tech-talk
<2024>
2025
2026
