1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: get asyn hostInfo
To: "[email protected]" <[email protected]>, Douglas Araujo <[email protected]>
Date: Thu, 4 Apr 2024 12:02:03 +0000
If you open the asynRecord OPI screen asynIPPortSetup does it correctly display the current IP host information in the widget labeled "Host info:"?  If so, then using the same code as in the asynRecord should work?
From: Tech-talk <[email protected]> on behalf of Douglas Araujo via Tech-talk <[email protected]>
Sent: Thursday, April 4, 2024 2:48 AM
To: [email protected] <[email protected]>
Subject: get asyn hostInfo
Hi all,
Does anyone know how to read the hostInfo value that is passed into the  drvAsynIPPortConfigure function ?
Basically, I have this in my startup script:
epicsEnvSet("IPADDR", "192.168.50.2")
epicsEnvSet("IPPORT", "65535")
drvAsynIPPortConfigure("L0", "$(IPADDR):$(IPPORT) UDP", 0, 0, 1)
And in my c++ code:
status = pasynOctetSyncIO->connect(address_info.c_str(), 0, &pasynUserOctet_, NULL); // where address_info is the portName
So, I tried following the steps inside asynRecord.c:
asynInterface *pasynInterface;
pasynInterface = pasynManager->findInterface(pasynUserOctet_, asynCommonType, 1);
void *asynOptionPvt;
asynOption *pasynOption;
pasynOption = (asynOption *) pasynInterface->pinterface;
asynOptionPvt = pasynInterface->drvPvt;
char hostbuff[100];
getOption(asynOptionPvt, pasynUserOctet_, "hostInfo", hostbuff, 100 );
std::cout << pasynUserOctet_->errorMessage << std::endl;
But I received the message error:
192.168.50.2:65535 UDP: Link already open!
Thanks in advance. -- Douglas Araujo
Re: get asyn hostInfo Douglas Araujo via Tech-talk
Prev: get asyn hostInfo Douglas Araujo via Tech-talk
Next: Re: get asyn hostInfo Douglas Araujo via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
