1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: iocStats Restart IOC PV does not work
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Thu, 4 Apr 2024 15:37:56 +0200
On Thu, 4 Apr 2024 at 11:36, Abdalla Ahmad via Tech-talk <[email protected]> wrote:
Although the issue does not appear on an IOC on the same server, I found out that the IOC is using relatively older modules versions; asyn 4.38 and stream device 2.8.10. I will try updating them and re-build the IOC.
Stream and ASYN are unrelated.
Have you updated iocStats, as Andrew suggested? That's the module that implements the exit record.
BTW.
Nothing happens, seems like the IOC shell is waiting for the “exit” to happen so I have to use Ctrl-C to force quit the IOC.
I hope you are aware that in the iocShell, Ctrl-C is *not* the same as "exit".
While "exit" or Ctrl-D (or the exit record) trigger an orderly shutdown that runs all registered exit hook routines, Ctrl-C stops the IOC immediately without running the exit hooks.
Depending on your device drivers, there might be a noticeable difference between the two. Often, there is not.
Cheers,
~Ralph
iocStats Restart IOC PV does not work Abdalla Ahmad via Tech-talk
Re: iocStats Restart IOC PV does not work Hu, Yong via Tech-talk
Re: iocStats Restart IOC PV does not work Johnson, Andrew N. via Tech-talk
RE: iocStats Restart IOC PV does not work Abdalla Ahmad via Tech-talk
Prev: Re: get asyn hostInfo Douglas Araujo via Tech-talk
Next: Re: get asyn hostInfo Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: RE: iocStats Restart IOC PV does not work Abdalla Ahmad via Tech-talk
Next: RE: iocStats Restart IOC PV does not work Zhang, Tong via Tech-talk
