1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: ADEuresys: New areaDetector driver for CoaXPress cameras using Euresys frame grabbers
From: "Yendell, Gary \(DLSLtd, RAL, LSCI\) via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, Mark Rivers <[email protected]>
Date: Thu, 11 Apr 2024 08:00:39 +0000
Hi Mark,
The section of the docs on file saving benchmarks is really interesting! Are you hoping that, with some improvements, running multiple IOCs with a pvaDriver and HDF5 writer will give the best performance?
Cheers,
Gary
From: Tech-talk <[email protected]> on behalf of Mark Rivers via Tech-talk <[email protected]>
Sent: 11 April 2024 00:11
To: [email protected] <[email protected]>
Subject: ADEuresys: New areaDetector driver for CoaXPress cameras using Euresys frame grabbers
Folks,
R1-0 of ADEuresys is now available.  ADEuresys is a driver for CoaXPress cameras using PCIe frame grabbers from Euresys.
CoaXPress is a high-speed camera interface using multiple coaxial cables.  Each cable can run up to 12.5 Gbits/s, and with 4 parallel cables the total speed is up to 50 Gbits/s.
CoaXPress is based on GenICam, so camera features are controlled the same way as with GigEVision and USBVision cameras.  The ADEuresys driver is derived from ADGenICam.
The driver has been tested on Windows 10 and Linux (CentOS 9 Stream) with the following cameras:
Model
Mikrotron EoSens 2.0MCX12
Adimec Q-12A
ViewWorks VNP604
Pixel dimensions
1920 x 1080
4096 x 3072
14192 x 10640
MegaPixels
2.1
12.6
151.0
CXP version
CXP-12 X4
CXP-6 X4
CXP-6 X4
Frames/s, Mono8
2247
187
6.5
GBytes/s. Mono8
4.66
2.35
1.0
Frames/s, Mono10
1798
152
6.2
GBytes/s. Mono10
7.46
3.83
2.0
Frames/s, Mono12
N.A
N.A
6.2
GBytes/s. Mono12
N.A
N.A
2.0
Note that the Mikrotron camera runs at 2,247 frames per second in Mono8 mode.
Home: https://github.com/areaDetector/ADEuresys
Documentation: https://areadetector.github.io/areaDetector/ADEuresys/ADEuresys.html
Cheers,
This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail. Any opinions expressed within this e-mail are those of the individual and not necessarily of Diamond Light Source Ltd.
Diamond Light Source Limited (company no. 4375679). Registered in England and Wales with its registered office at Diamond House, Harwell Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom.
RE: ADEuresys: New areaDetector driver for CoaXPress cameras using Euresys frame grabbers Mark Rivers via Tech-talk
Prev: Re: urldefense.us URLs? Chris Johns via Tech-talk
Next: RE: ADEuresys: New areaDetector driver for CoaXPress cameras using Euresys frame grabbers Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: ADEuresys: New areaDetector driver for CoaXPress cameras using Euresys frame grabbers Mark Rivers via Tech-talk
