1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: RE: Readback of output variables in adsDriver
To: "Meyer, Markus" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 12 Apr 2024 16:11:27 +0000
Hi Markus,
There are 2 separate cases here:
1) The PV value getting set to the PLC value during iocInit.
2) The PV value getting set to the PLC value when the PLC values changes after iocInit.
Case 1 is handled as follows:
- During iocInit the ao record device support (devAsynFloat64.c) does a read from the driver to get the current PLC value.  If that read operation returns asynSuccess then the PV should be set to the PLC value, otherwise it is not changed.  This definitely works fine with the Modbus driver, for example.  I am not sure about the adsDriver, since I have not used it.  You can add debugging to the driver to track that down.
Case 2 is handled by adding the line you did to database:
    info(asyn:READBACK, "1")
That should make the ao record value update to match the PLC value when the PLC value is changed outside of EPICS.  Note that this line is NOT required for getting the behavior described in Case 1 above.
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of Meyer, Markus via Tech-talk
Sent: Friday, April 12, 2024 10:25 AM
To: [email protected]
Subject: Readback of output variables in adsDriver
Dear all,
I am evaluating possibilities to communicate with a plc and other hardware
from beckhoff. I have successfully build the adsDriver [1] device support
and it seems to work very well for input variables. I can also write output
variables, but if the value gets changed on the plc itself (e.g. by the
interlock logic or by another connected protocol) it is not synced back to
the pv. It also seems that the current value is not initially read on
startup of the IOC.
For example, this is the pv definition:
record(ao, "$(P):IC:CB01-SSet") {
    field(DTYP, "asynFloat64")
    field(PREC, "2")
    field(EGU,  "%")
    field(DRVH, "100")
    field(DRVL, "-100")
    field(OUT,  "@asyn($(PORT) 0 0) REAL W P=PLC_TC3 V=HMI.IC.CB01.SSet")
Before I start the IOC, the plc value is set to 2. If I start the IOC, the
value of the pv is set to 0. The Timestamp is updated. The value in the plc
gets not changed. I expected, that the pv value is also set to 2. Writing a
value to the pv is working as expected.
Did I miss something here? What can I do to subscribe for changes of output
variables?
Markus
[1] https://urldefense.us/v3/__https://github.com/Cosylab/adsDriver__;!!G_uCfscf7eWS!eovU-aYXFfsZIvbTx6Y3tTGma4zwbWLi1xy-LUyW3RghomFH88t9jP45toKnZq8oo1pt5gT5tQhGnPd9QXmCruzGkJg$
Re: Readback of output variables in adsDriver Torsten Bögershausen via Tech-talk
Re: Readback of output variables in adsDriver Jure Varlec via Tech-talk
Readback of output variables in adsDriver Meyer, Markus via Tech-talk
Prev: Readback of output variables in adsDriver Meyer, Markus via Tech-talk
Next: Remote reset of MVME-2700 possible through serial console Jennings, Guy via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Next: Re: Readback of output variables in adsDriver Torsten Bögershausen via Tech-talk
