1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: streamdevice and input strings
From: Pierrick M Hanlet via Tech-talk <[email protected]>
Date: Tue, 16 Apr 2024 23:24:08 +0000
Hi all,
I'm on a linux box with AL9.3, base 7.07, and StreamDevice 2.8.24.
I have a string input, which the controller gives as: A1,A2,B1,B2.
I want to read them individually as separate names, i.e. separate records.
My protocol is:
get_names {
     separator=",";
     out "CID";
     in  "%(\$1:G1Name)s%(\$1:G2Name)s%(\$1:G3Name)s%(\$1:G4Name)s";
although, I've also tried as:
get_names {
     separator=",";
     out "CID";
     in "%(\$1:G1Name)s,%(\$1:G2Name)s,%(\$1:G3Name)s,%(\$1:G4Name)s";
or as:
get_names {
     out "CID";
Of course, it works perfectly if I have:
get_names {
     out "CID";
     in "%(\$1:G1Name)2c,%(\$1:G2Name)2c,%(\$1:G3Name)2c,%(\$1:G4Name)2c";
However, the name can be up to 8 characters long.
I don't understand why separator doesn't work as I'm using it.
Thank you,
Pierrick
Pierrick Hanlet
Fermi National Accelerator
Accelerator Front End Controls
+1-630-840-5555 -- lab
+1-312-687-4980 -- mobile
"Whether you think you can or think you can't, you're right" -- Henry Ford
Re: streamdevice and input strings Zimoch Dirk via Tech-talk
Prev: Phoebus macro question Jörn Dreyer via Tech-talk
Next: Re: streamdevice and input strings Zimoch Dirk via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
