1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: RE: EXTERNAL: RE: EPICS 7.0.8 and 7.0.7 Windows build failure
From: Revell Gary via Tech-talk <[email protected]>
To: Timo Korhonen <[email protected]>, Freddie Akeroyd <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 18 Apr 2024 14:33:07 +0000
Hi Timo,
Yes, it does pay to RT Fine M and I actually built EPICS via the installation guide here:
https://epics.anl.gov/base/R7-0/8-docs/README.html
and so missed it, although it to states make V4.1.
Anyway, it’s built now and I’m just stumbling along trying to work out what to do with it. I’ve done the post installation example with test.db and now looking at the Phoebus Display Manager.
Any advice on approach to take is gratefully received, I’m the sole resource here looking at EPICS so there’s a steep learning curve.
Thanks!
Gary
Sent: Thursday, April 18, 2024 3:15 PM
To: Revell Gary <[email protected]>; Freddie Akeroyd <[email protected]>; [email protected]
Subject: Re: EXTERNAL: RE: EPICS 7.0.8 and 7.0.7 Windows build failure
You don't often get email from [email protected]. Learn why this is important
PHISHING ALERT - This email originated from outside of AWE
DO YOU TRUST THIS EMAIL? If not, click here for more guidance or use the ‘Report Message’ button on your Outlook toolbar to send this message to the PhishTank.
Hi Gary,
Sorry that you had to waste time with this issue… now you know, but maybe others will benefit from the documentation here, which also lists the required tools.
(Let us see how well this link gets through…)
Cheers,
Timo
From: Tech-talk <[email protected]> on behalf of Revell Gary via Tech-talk <[email protected]>
Reply to: Revell Gary <[email protected]>
Date: Thursday, 18 April 2024 at 12:40
To: Freddie Akeroyd <[email protected]>, "[email protected]" <[email protected]>
Hi Freddie,
I was using make v3.8.1 initially, but then installed V4.4.1 and….. the distclean and build ran to completion!
Hmmm, bit of a shame this wasn’t documented anywhere (that I could easily see!) as I wasted a few hours yesterday trying to work out what the problem was.
Again, thanks very much for your help!
Best regards
Gary
From: Freddie Akeroyd - STFC UKRI <[email protected]>
Sent: Thursday, April 18, 2024 10:00 AM
To: Revell Gary <[email protected]>; [email protected]
Subject: EXTERNAL: RE: EPICS 7.0.8 and 7.0.7 Windows build failure
Hi Gary,
Which version of make are you using? I think when I’ve seen this before it was caused by make version 3.8, epics needs make 4.x
Freddie
From: Tech-talk <[email protected]> On Behalf Of Revell Gary via Tech-talk
Sent: Wednesday, April 17, 2024 4:40 PM
To: [email protected]
Subject: RE: EPICS 7.0.8 and 7.0.7 Windows build failure
Hi everyone,
I’m trying to evaluate the use of EPICS and so wanted to install it on my Windows 10 VM (8GB RAM).
When building V7.0.8 on a Windows 10 VM and V7.0.7 (build shown below) I keep getting the same error, see below:
make[5]: Entering directory `C:/Dev/EPICS/base-7.0.7/modules/database/test/tools/O.windows-x64'
perl -CSD C:/Dev/EPICS/base-7.0.7/bin/windows-x64/expandVars.pl  -t ../../../../.. -a windows-x64 ../Base.plt Base.t
perl -CSD C:/Dev/EPICS/base-7.0.7/bin/windows-x64/expandVars.pl  -t ../../../../.. -a windows-x64 ../Breaktable.plt Breaktable.t
perl -CSD C:/Dev/EPICS/base-7.0.7/bin/windows-x64/expandVars.pl  -t ../../../../.. -a windows-x64 ../DBD.plt DBD.t
perl -CSD C:/Dev/EPICS/base-7.0.7/bin/windows-x64/expandVars.pl  -t ../../../../.. -a windows-x64 ../Device.plt Device.t
perl -CSD C:/Dev/EPICS/base-7.0.7/bin/windows-x64/expandVars.pl  -t ../../../../.. -a windows-x64 ../Driver.plt Driver.t
perl -CSD C:/Dev/EPICS/base-7.0.7/bin/windows-x64/expandVars.pl  -t ../../../../.. -a windows-x64 ../Function.plt Function.t
perl -CSD C:/Dev/EPICS/base-7.0.7/bin/windows-x64/expandVars.pl  -t ../../../../.. -a windows-x64 ../Menu.plt Menu.t
perl -CSD C:/Dev/EPICS/base-7.0.7/bin/windows-x64/expandVars.pl  -t ../../../../.. -a windows-x64 ../Recfield.plt Recfield.t
perl -CSD C:/Dev/EPICS/base-7.0.7/bin/windows-x64/expandVars.pl  -t ../../../../.. -a windows-x64 ../Recordtype.plt Recordtype.t
perl -CSD C:/Dev/EPICS/base-7.0.7/bin/windows-x64/expandVars.pl  -t ../../../../.. -a windows-x64 ../Registrar.plt Registrar.t
perl -CSD C:/Dev/EPICS/base-7.0.7/bin/windows-x64/expandVars.pl  -t ../../../../.. -a windows-x64 ../Variable.plt Variable.t
make[5]: Leaving directory `C:/Dev/EPICS/base-7.0.7/modules/database/test/tools/O.windows-x64'
make[4]: Leaving directory `C:/Dev/EPICS/base-7.0.7/modules/database/test/tools'
make[3]: Leaving directory `C:/Dev/EPICS/base-7.0.7/modules/database/test'
make[2]: Leaving directory `C:/Dev/EPICS/base-7.0.7/modules/database'
make -C ./pvData install
make[2]: Entering directory `C:/Dev/EPICS/base-7.0.7/modules/pvData'
make -C ./configure install
make[3]: Entering directory `C:/Dev/EPICS/base-7.0.7/modules/pvData/configure'
perl -CSD C:/Dev/EPICS/base-7.0.7/modules/pvData/configure/C:/Dev/EPICS/base-7.0.7/bin/windows-x64/makeMakefile.pl O.windows-x64 ../..
Can't open perl script "C:/Dev/EPICS/base-7.0.7/modules/pvData/configure/C:/Dev/EPICS/base-7.0.7/bin/windows-x64/makeMakefile.pl": Invalid argument
make[3]: *** [O.windows-x64] Error 22
make[3]: Leaving directory `C:/Dev/EPICS/base-7.0.7/modules/pvData/configure'
make[2]: *** [configure.install] Error 2
make[2]: Leaving directory `C:/Dev/EPICS/base-7.0.7/modules/pvData'
make[1]: *** [pvData.install] Error 2
make[1]: Leaving directory `C:/Dev/EPICS/base-7.0.7/modules'
make: *** [modules.install] Error 2
The problem arises during the execution of the makeMakefile.pl script, and the pathname has two directories in it for some reason (C:/Dev/EPICS/base-7.0.7/…… ) is appearing twice and therefor and invalid pathname. I believe I’ve followed the installation instructions OK.
Any help/advice is gratefully appreciated.
Gary Revell
Senior Software Engineer
Orion Laser Facility
Office: 01189 852987
AWE Aldermaston, Reading, RG7 4PR
www.awe.co.uk
The information in this email and in any attachment(s) is commercial in confidence. If you are not the named addressee(s) or if you receive this email in error then any distribution, copying or use of this communication or the information in it is strictly prohibited. Please notify us immediately by email at admin.internet(at)awe.co.uk, and then delete this message from your computer. While attachments are virus checked, AWE plc does not accept any liability in respect of any virus which is not detected. AWE Plc Registered in England and Wales Registration No 02763902 AWE, Aldermaston, Reading, RG7 4PR
RE: EPICS 7.0.8 and 7.0.7 Windows build failure Revell Gary via Tech-talk
RE: EPICS 7.0.8 and 7.0.7 Windows build failure Freddie Akeroyd - STFC UKRI via Tech-talk
RE: EXTERNAL: RE: EPICS 7.0.8 and 7.0.7 Windows build failure Revell Gary via Tech-talk
Re: EXTERNAL: RE: EPICS 7.0.8 and 7.0.7 Windows build failure Timo Korhonen via Tech-talk
Prev: Re: EXTERNAL: RE: EPICS 7.0.8 and 7.0.7 Windows build failure Timo Korhonen via Tech-talk
Next: Re: EXTERNAL: RE: EPICS 7.0.8 and 7.0.7 Windows build failure Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
