1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Re: Windows PVA server only responding to broadcast?
From: "Guruswamy, Tejas via Tech-talk" <[email protected]>
Date: Thu, 18 Apr 2024 23:18:49 +0000
I should have also added: CA for this same IOC responds to both unicast and broadcast. Issue exists only for PVA.
>C:\cygwinx64\bin\env.exe EPICS_CA_AUTO_ADDR_LIST=yes .\caget 6IDFF:alive
6IDFF:alive                    146
>C:\cygwinx64\bin\env.exe EPICS_CA_AUTO_ADDR_LIST=no EPICS_CA_ADDR_LIST=127.0.0.1 .\caget 6IDFF:alive
6IDFF:alive                    148
>C:\cygwinx64\bin\env.exe EPICS_CA_AUTO_ADDR_LIST=no EPICS_CA_ADDR_LIST=10.54.121.48 .\caget 6IDFF:alive
6IDFF:alive                    149
> casr
Channel Access Server V4.13
Tejas Guruswamy
APS, XSD-DET
Argonne National Laboratory
From: Tech-talk <[email protected]> on behalf of Guruswamy, Tejas via Tech-talk <[email protected]>
Sent: Thursday, April 18, 2024 6:04 PM
To: [email protected] <[email protected]>
Subject: Windows PVA server only responding to broadcast?
Hi tech-talk,
Strange behavior with the pvaServer on a Windows 11 IOC I can't understand – it only seems to respond to broadcast name searches, not unicast.
Windows Firewall says it is off.
As an example: testing from the same machine the IOC is running on, which has only one network interface (IP 10.54.121.48):
If I allow broadcast searches, works fine:
>C:\cygwinx64\bin\env.exe EPICS_PVA_AUTO_ADDR_LIST=yes .\pvget -d 6IDFF:Pva1:Image
2024-04-18T18:00:40.816 Creating datagram socket from: 0.0.0.0:59556.
2024-04-18T18:00:40.817 Broadcast address #0: 10.54.121.255:5076. (not unicast)
2024-04-18T18:00:40.817 Setting up UDP for interface 10.54.121.48/255.255.255.0, broadcast 10.54.121.255, dest <none>.
2024-04-18T18:00:40.818 Creating datagram socket from: 10.54.121.48:5076.
2024-04-18T18:00:40.819 Creating datagram socket from: 0.0.0.0:5076.
2024-04-18T18:00:40.819 Local multicast enabled on 127.0.0.1/224.0.0.128:5076.
2024-04-18T18:00:40.819 Sending 62 bytes 0.0.0.0:59556 -> 10.54.121.255:5076.
2024-04-18T18:00:40.820 UDP Client Rx (62) 10.54.121.48:5076 <- 10.54.121.48:59556
Waiting...
2024-04-18T18:00:40.820 UDP Client Rx (62) 0.0.0.0:5076 <- 10.54.121.48:59556
2024-04-18T18:00:40.820 UDP Client Rx (53) 0.0.0.0:59556 <- 10.54.121.48:52492
2024-04-18T18:00:40.821 Connecting to PVA server: 10.54.121.48:5075.
2024-04-18T18:00:40.822 Opening socket to PVA server 10.54.121.48:5075, attempt 1.
2024-04-18T18:00:40.827 Socket connected to PVA server: 10.54.121.48:5075.
2024-04-18T18:00:40.829 Acquiring transport to 10.54.121.48:5075.
2024-04-18T18:00:40.837 Connected to PVA server: 10.54.121.48:5075.
2024-04-18T18:00:40.838 UDP Client Rx (53) 0.0.0.0:59556 <- 10.54.121.48:52492
6IDFF:Pva1:Image epics:nt/NTNDArray:1.0
2024-04-18T18:00:40.865 Releasing TCP transport to 10.54.121.48:5075.
2024-04-18T18:00:40.866 TCP socket to 10.54.121.48:5075 is to be closed.
2024-04-18T18:00:40.866 UDP socket 0.0.0.0:0 closed.
2024-04-18T18:00:40.866 UDP socket 10.54.121.48:5076 closed.
2024-04-18T18:00:40.867 UDP socket 0.0.0.0:5076 closed.
Done
Then I remove the broadcast option, and I get a timeout, despite the same address which just responded being in EPICS_PVA_ADDR_LIST:
>C:\cygwinx64\bin\env.exe EPICS_PVA_AUTO_ADDR_LIST=no EPICS_PVA_ADDR_LIST=10.54.121.48 .\pvget -d 6IDFF:Pva1:Image
2024-04-18T17:50:20.693 Creating datagram socket from: 0.0.0.0:65265.
2024-04-18T17:50:20.694 Broadcast address #0: 10.54.121.48:5076. (unicast)
2024-04-18T17:50:20.694 Setting up UDP for interface 10.54.121.48/255.255.255.0, broadcast 10.54.121.255, dest <none>.
2024-04-18T17:50:20.694 Creating datagram socket from: 10.54.121.48:5076.
2024-04-18T17:50:20.694 Creating datagram socket from: 0.0.0.0:5076.
2024-04-18T17:50:20.694 Local multicast enabled on 127.0.0.1/224.0.0.128:5076.
2024-04-18T17:50:20.695 Sending 62 bytes 0.0.0.0:65265 -> 10.54.121.48:5076.
Waiting...
2024-04-18T17:50:20.928 Sending 62 bytes 0.0.0.0:65265 -> 10.54.121.48:5076.
2024-04-18T17:50:21.394 Sending 62 bytes 0.0.0.0:65265 -> 10.54.121.48:5076.
2024-04-18T17:50:22.325 Sending 62 bytes 0.0.0.0:65265 -> 10.54.121.48:5076.
2024-04-18T17:50:24.188 Sending 62 bytes 0.0.0.0:65265 -> 10.54.121.48:5076.
Timeout
6IDFF:Pva1:Image 2024-04-18T17:50:25.698 UDP socket 0.0.0.0:0 closed.
2024-04-18T17:50:25.699 UDP socket 10.54.121.48:5076 closed.
2024-04-18T17:50:25.700 UDP socket 0.0.0.0:5076 closed.
Done
The localhost IP does work:
>C:\cygwinx64\bin\env.exe EPICS_PVA_AUTO_ADDR_LIST=no EPICS_PVA_ADDR_LIST=127.0.0.1 .\pvget -d 6IDFF:Pva1:Image
2024-04-18T17:51:10.433 Creating datagram socket from: 0.0.0.0:61636.
2024-04-18T17:51:10.435 Broadcast address #0: 127.0.0.1:5076. (unicast)
2024-04-18T17:51:10.435 Setting up UDP for interface 10.54.121.48/255.255.255.0, broadcast 10.54.121.255, dest <none>.
2024-04-18T17:51:10.437 Creating datagram socket from: 10.54.121.48:5076.
2024-04-18T17:51:10.438 Creating datagram socket from: 0.0.0.0:5076.
2024-04-18T17:51:10.440 Local multicast enabled on 127.0.0.1/224.0.0.128:5076.
2024-04-18T17:51:10.441 Sending 62 bytes 0.0.0.0:61636 -> 127.0.0.1:5076.
Waiting...
2024-04-18T17:51:10.442 UDP Client Rx (53) 0.0.0.0:61636 <- 127.0.0.1:52492
2024-04-18T17:51:10.442 Connecting to PVA server: 127.0.0.1:5075.
2024-04-18T17:51:10.443 Opening socket to PVA server 127.0.0.1:5075, attempt 1.
2024-04-18T17:51:10.443 Socket connected to PVA server: 127.0.0.1:5075.
2024-04-18T17:51:10.444 Acquiring transport to 127.0.0.1:5075.
2024-04-18T17:51:10.453 Connected to PVA server: 127.0.0.1:5075.
2024-04-18T17:51:10.476 Releasing TCP transport to 127.0.0.1:5075.
2024-04-18T17:51:10.476 TCP socket to 127.0.0.1:5075 is to be closed.
2024-04-18T17:51:10.477 UDP socket 0.0.0.0:0 closed.
2024-04-18T17:51:10.477 UDP socket 10.54.121.48:5076 closed.
2024-04-18T17:51:10.478 UDP socket 0.0.0.0:5076 closed.
Done
It's the same for any other computers accessing this IOC – broadcast works, unicast does not.
Info from the IOC:
> pvasr
pvAccess Server v7.1.6-SNAPSHOT
Active configuration (w/ defaults)
EPICS_PVAS_INTF_ADDR_LIST = 0.0.0.0:5075
EPICS_PVAS_BEACON_ADDR_LIST =
EPICS_PVAS_AUTO_BEACON_ADDR_LIST = YES
EPICS_PVAS_BEACON_PERIOD = 15
EPICS_PVAS_BROADCAST_PORT = 5076
EPICS_PVAS_SERVER_PORT = 5075
EPICS_PVAS_PROVIDER_NAMES = QSRV local
> ​epicsEnvShow
EPICS_VERSION_FULL=7.0.6.2-DEV
Any ideas? This is a problem because it means we cannot access this IOC from any other subnets.
Tejas Guruswamy
APS, XSD-DET
Windows PVA server only responding to broadcast? Guruswamy, Tejas via Tech-talk
Prev: Windows PVA server only responding to broadcast? Guruswamy, Tejas via Tech-talk
Next: mxDAQ EPICS module missing Jörn Dreyer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
