1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: Editing .pb files for the purpose of appending data to them
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Tynan Ford <[email protected]>, Sky Brewer <[email protected]>
Date: Tue, 30 Apr 2024 07:47:49 -0700
On 4/29/24 08:19, Tynan Ford via Tech-talk wrote:
Hi Sky,
We have wondered if it's possible to append data to the appliance pb files since we have data from previous archivers that goes back many years. It would be useful to have that data imported into the appliance so all archived data can be retrieved via the same method. I naively thought we could write a script to create pb files like TESTPV:2001.pb, TESTPV:2002.pb, etc but I'm curious what you think?
It is probably suffering from bit-rot at this point,
but my old Channel Archiver to Archiver Appliance
direct file converter is still available:
https: //github.com/mdavidsaver/ca2aa
Thanks
Tynan
On Wed, Apr 24, 2024 at 2:46 AM Sky Brewer via Tech-talk <[email protected] <mailto:[email protected]>> wrote:
    Hi Windsor,____
    __ __
    Some examples of python code for handling the pb files can be found at:____
    __ __
    https://urldefense.us/v3/__https://github.com/zhangt58/PyArchAppl/blob/master/main/data/pb/decode.py__;!!G_uCfscf7eWS!fvGpipmB7FsIn0XQsrK2CNDsPkaJASxwivcnk14AAtitA7Bx5MtNqAKPuyMGArcX3LaYhxBPVOQGyjxeSiEsE0wKHA$  <https://urldefense.us/v3/__https://github.com/zhangt58/PyArchAppl/blob/master/main/data/pb/decode.py__;!!G_uCfscf7eWS!b5YgNXV8LWnk1VGBnMvzi-WzDnvd0WROFnruh9I275nM8J9YqqhG98bXfcER4KCiJ6M4_LjfjjRhn2omsWogAg71$> ____
    https://urldefense.us/v3/__https://github.com/dls-controls/aapy/blob/master/aa/pb.py__;!!G_uCfscf7eWS!fvGpipmB7FsIn0XQsrK2CNDsPkaJASxwivcnk14AAtitA7Bx5MtNqAKPuyMGArcX3LaYhxBPVOQGyjxeSiGYHNJ83Q$  <https://urldefense.us/v3/__https://github.com/dls-controls/aapy/blob/master/aa/pb.py__;!!G_uCfscf7eWS!b5YgNXV8LWnk1VGBnMvzi-WzDnvd0WROFnruh9I275nM8J9YqqhG98bXfcER4KCiJ6M4_LjfjjRhn2omsZN2X7I9$> ____
    and ____
    https://urldefense.us/v3/__https://gitlab.esss.lu.se/ics-software/py-epicsarchiver/-/blob/master/epicsarchiver/pb.py?ref_type=heads__;!!G_uCfscf7eWS!fvGpipmB7FsIn0XQsrK2CNDsPkaJASxwivcnk14AAtitA7Bx5MtNqAKPuyMGArcX3LaYhxBPVOQGyjxeSiGfvj4MkQ$  <https://urldefense.us/v3/__https://gitlab.esss.lu.se/ics-software/py-epicsarchiver/-/blob/master/epicsarchiver/pb.py?ref_type=heads__;!!G_uCfscf7eWS!b5YgNXV8LWnk1VGBnMvzi-WzDnvd0WROFnruh9I275nM8J9YqqhG98bXfcER4KCiJ6M4_LjfjjRhn2omseE1GJdN$> ____
    __ __
    Obviously, I prefer my own code 😊____
    __ __
    In terms of appending data, could you explain your use case? I don’t know why you would want to append data from outside the archiver.____
    The archiver makes many assumptions about these files in terms of what data is in them dependent on the name of the file. I would be ____
    Careful about altering them.____
    __ __
    A simple solution can be to push data into the files using a PV! Note that the archiver doesn’t do any checks that timestamps correspond to the current time. ____
    Only that they are sequential. So as long as you are adding new events you can push extra events in.____
    __ __
    A second solution is to use the merge data from another cluster in the ETL process. You can see some documentation at https://urldefense.us/v3/__https://slacmshankar.github.io/epicsarchiver_docs/redundancy.html__;!!G_uCfscf7eWS!fvGpipmB7FsIn0XQsrK2CNDsPkaJASxwivcnk14AAtitA7Bx5MtNqAKPuyMGArcX3LaYhxBPVOQGyjxeSiH7yrtgUA$  <https://urldefense.us/v3/__https://slacmshankar.github.io/epicsarchiver_docs/redundancy.html__;!!G_uCfscf7eWS!b5YgNXV8LWnk1VGBnMvzi-WzDnvd0WROFnruh9I275nM8J9YqqhG98bXfcER4KCiJ6M4_LjfjjRhn2omscva_VhG$> ____
    I can probably create an example if you need it.____
    __ __
    You could then set up a dummy PV to push the data you want in, and allow the archiver ETL process to merge the data for you.____
    __ __
    I hope that helps.____
    Sky____
    __ __
    __ __
    __ __
Re: Editing .pb files for the purpose of appending data to them Sky Brewer via Tech-talk
Re: Editing .pb files for the purpose of appending data to them Tynan Ford via Tech-talk
Prev: Re: AreaDetectors - ADPylon Mark Rivers via Tech-talk
Next: RE: Using PyAT Blomley, Edmund (IBPT) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Re: Editing .pb files for the purpose of appending data to them Tynan Ford via Tech-talk
Next: Re: Editing .pb files for the purpose of appending data to them Sky Brewer via Tech-talk
