Re: Does it have something to do with reliability?
Yes. Originally, we were using JCA to talk to EPICS PVS and that would core dump occasionally. And we really do NOT want the ETL workflows to be interrupted abruptly. This has since changed in that we use the Java versions of the EPICS libraries and those are
quite stable these days.
Also, the workloads are quite different between the components and separating them out may be less burdensome on GC.
It is also sometimes useful to have the ability to just restart one component - like the retrieval component which can sometimes get into a death spiral of full GC.
Hope that helps.
Murali
Re: difference between DB and DB_INSTALLS Ralph Lange via Tech-talk
Re: difference between DB and DB_INSTALLS Johnson, Andrew N. via Tech-talk
<2024>
2025
2026
4 instances vs 1 instance of Tomcat for ArchiverAppliance NICOLE Remi via Tech-talk
difference between DB and DB_INSTALLS William Kirstaedter via Tech-talk
<2024>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
