1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Re: ADUrl and digest authentication
From: "Heesterman, Peter via Tech-talk" <[email protected]>
Date: Fri, 17 May 2024 16:22:25 +0000
Hi Tomasz,
You should be able to send the password within the URL PV that you apply to the module.
e.g. in your case you would likely set cam1:URL1 to https://<user:password>@x.x.x.x/ISAPI/Streaming/channels/1/picture
I don’t know about encryption, I haven’t tried that.
If you have security concerns, you should be aware that it would be possible to read the URL value that you set that contains the password.
In general, the ADURL module can operate using any URL that is similarly used within e.g. a web browser.
Cheers,
Peter.
This message contains information that may be privileged or confidential and is the property of the Capgemini Group. It is intended only for the person to whom it is addressed. If you are not the intended recipient, you are not authorized to read, print, retain, copy, disseminate, distribute, or use this message or any part thereof. If you receive this message in error, please notify the sender immediately and delete all copies of this message.
Prev: Re: EPICS and EPICS+PVXS internal threading of IOCs Han Lee via Tech-talk
Next: Re: difference between DB and DB_INSTALLS Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Prev: ADUrl and digest authentication Tomasz Brys via Tech-talk
Next: Changing runtime limits with Channel Access Alessandra Palazzo via Tech-talk
