On Mon, 3 Jun 2024 at 06:46, Jörn Dreyer via Tech-talk <[email protected]> wrote:
Another common option is using a "console server" or 'terminal server". These are COTS boxes that connect multiple serial lines (RS-232, RS-485) to TCP/IP, typically assigning a dedicated port to each serial line. Many installations use "MOXA boxes" (MOXA NPort 6000 series terminal servers), but there are other vendors with similar products. Such boxes are industrial hardware, combining robustness and high availability with low management and maintenance effort. On the IOC, the drvAsynSerialPortConfigure is replaced by drvAsynIPPortConfigure. That's typically all that needs to change. And as that IOC only does network IO, it can easily be moved to a virtualized host, possibly removing the need for your CentOS PC. Cheers, ~Ralph
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
