1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Subject: Re: Errors during building of asyn package
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: Yury Malevich - STFC UKRI <yury.malevich at stfc.ac.uk>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Mon, 1 Jul 2024 13:20:17 +0000
Hi Yury,
Since EPICS base and asyn are installed in your home directory there is no need to use sudo, and perhaps that is the problem.
Please try building without sudo.
From: Yury Malevich - STFC UKRI <yury.malevich at stfc.ac.uk>
Sent: Monday, July 1, 2024 5:31 AM
To: Mark Rivers <rivers at cars.uchicago.edu>; tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: RE: Errors during building of asyn package
Hi Mark,
I am not sure how to check the version of EPICS base installed. Standard epics-base –version etc. don’t work.
But I cloned it las week using:
git clone --recursive https://github.com/epics-base/epics-base.git
so seemingly it is 7.0.8
I cloned asyn last week as well with
git clone https://github.com/epics-modules/asyn.git
so it is seemingly 4-44-2
OS is ubuntu-22.04.4-desktop-amd64
This is an output of sudo make after sudo make clean:
sudo make
make -C ./configure install
make[1]: Entering directory '/home/yury/EPICS/support/asyn/configure'
perl -CSD /home/yury/EPICS/epics-base/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../..
mkdir -p O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[2]: Entering directory '/home/yury/EPICS/support/asyn/configure/O.linux-x86_64'
perl -CSD /home/yury/EPICS/epics-base/bin/linux-x86_64/convertRelease.pl checkRelease
EPICS_BASE must be set in a configure/RELEASE file.
make[2]: *** [/home/yury/EPICS/epics-base/configure/RULES_BUILD:208: checkRelease] Error 2
make[2]: Leaving directory '/home/yury/EPICS/support/asyn/configure/O.linux-x86_64'
make[1]: *** [/home/yury/EPICS/epics-base/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[1]: Leaving directory '/home/yury/EPICS/support/asyn/configure'
make: *** [/home/yury/EPICS/epics-base/configure/RULES_DIRS:85: configure.install] Error 2
Yury
Sent: 28 June 2024 14:41
To: Malevich, Yury (STFC,RAL,CLF) <yury.malevich at stfc.ac.uk>; tech-talk at aps.anl.gov
Hi Yury,
What version of EPICS base are you using?
What version of asyn are you using?
What operating system are you using?
Please send the complete output when you run the following at the top-level of asyn:
make clean
make
Sent: Friday, June 28, 2024 4:40 AM
Hi Mark,
No, there is no /home/yury/EPICS/support/configure/EPICS_BASE.linux-x86_64 file either.
/home/yury/EPICS/support/ folder contains only asyn folder.
In the RELEASE file I only replaced
SUPPORT=/corvette/home/epics/support
with
SUPPORT=$(HOME)/EPICS/support
-include $(TOP)/../configure/SUPPORT.$(EPICS_HOST_ARCH)
and
EPICS_BASE=/corvette/usr/local/epics/base-7.0.7
with
EPICS_BASE=${HOME}/EPICS/epics-base
-include $(TOP)/../configure/EPICS_BASE.$(EPICS_HOST_ARCH)
Also I added HOME=/home/yury line
Yury
Sent: 27 June 2024 22:27
Hi Yury,
Ø  /home/yury/EPICS/configure/EPICS_BASE.linux-x86_64 doesn’t exist. And there is no folder called “configure” in /home/yury/EPICS/.
That was my mistake.  I meant to ask if this file exists:
Sent: Thursday, June 27, 2024 10:04 AM
To: Mark Rivers <
Hi Mark,
Thank you for your help.
As for asyn/configure/RELEASE file, its contains that I showed are copy-pasted from and according to the
Installation on Linux / MacOS — EPICS Documentation documentation (epics-controls.org)
guide. I deleted all commented lines for brevity.
Here is the whole file:
# RELEASE Location of external products
# Define the following Required or Optional
# either in this file, or in a RELEASE.local
HOME=/home/yury
#SUPPORT=/corvette/home/epics/support
# Optional
# IPAC is only necessary if support for Greensprings IP488 is required
# IPAC release V2-7 or later is required.
# It can be obtained here: https://github.com/epics-modules/ipac
#IPAC=$(SUPPORT)/ipac-2-16
# Optional
# SEQ is required for testIPServer
# It can be obtained here: https://www-csr.bessy.de/control/SoftDist/sequencer/Manual.html
#SNCSEQ=$(SUPPORT)/seq-2-2-9
# Optional
# For sCalcout support in asynOctet - applications include asynCalc.dbd
# It can be obtained here: https://github.com/epics-modules/calc
#CALC=$(SUPPORT)/calc-3-7-4
# Optional
# If CALC was built with SSCAN support then SSCAN must be defined for testEpicsApp
# It can be obtained here: https://github.com/epics-modules/sscan
#SSCAN=$(SUPPORT)/sscan-2-11-5
# Required
# EPICS_BASE 3.14.6 or later is required
# It can be obtained here: https://github.com/epics-base/epics-base
#EPICS_BASE=/corvette/usr/local/epics/base-7.0.7
#-include $(TOP)/../RELEASE.local
#-include $(TOP)/../RELEASE.$(EPICS_HOST_ARCH).local
#-include $(TOP)/configure/RELEASE.local
Yury
Sent: 27 June 2024 15:09
Hi Yuri,
I can see from your asyn/configure/RELEASE file that you are using a very old version of asyn.  The last version that contained the lines you have was R4-36 in 2019.  I suggest you update to a new version.
Sent: Thursday, June 27, 2024 8:56 AM
yury.malevich at stfc.ac.uk>; tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Does this file exist?  It is optionally included in asyn/configure/RELEASE after EPICS_BASE is defined there.
If so, does it correctly define EPICS_BASE?
Sent: Thursday, June 27, 2024 8:31 AM
To: Mark Rivers <
Hi Mark,
Yes, I think I did.
My /home/yury/EPICS/support/asyn/configure/RELEASE file looks like that:
HOME=/home/yury
Yury
Sent: 27 June 2024 14:18
To:
tech-talk at aps.anl.gov; Malevich, Yury (STFC,RAL,CLF) <yury.malevich at stfc.ac.uk>
Hi Yury,
You need to edit asyn/configure/RELEASE to define the path to EPICS_BASE.  This is what mine looks like:
Yours should probably look like this:
EPICS_BASE=/home/yury/EPICS/epics-base
Did you edit that file correctly?
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Yury Malevich - STFC UKRI via Tech-talk <tech-talk at aps.anl.gov>
Sent: Thursday, June 27, 2024 7:58 AM
To:
Subject: Errors during building of asyn package
Hi All,
I am using virtual machine running ubuntu-22.04.4-desktop-amd64.
I am a newbie in EPICS, trying to follow this guide:
But when I am trying to build asyn package I have some errors:
make
Any assistance would be greatly appreciated.
Thanks.
Yury
RE: Errors during building of asyn package Yury Malevich - STFC UKRI via Tech-talk
Re: Errors during building of asyn package Mark Rivers via Tech-talk
RE: Errors during building of asyn package Mark Rivers via Tech-talk
Prev: Re: Errors during building of asyn package Timo Korhonen via Tech-talk
Next: RE: Errors during building of asyn package Yury Malevich - STFC UKRI via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
ANJ, 11 Sep 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
