1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Subject: Alarm Server Periodically Disconnects from IOCS
From: "Srinivas, Dhruv via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 16 Jul 2024 16:36:28 +0000
Hi everyone,
I’ve implemented an alarm server across a network but am experiencing a periodic issue. On occasion, the alarm server marks all records from an IOC as disconnected before returning to an OK state shortly afterwards.
For details on the setup, I have kafka and zookeeper setup along with the alarm server. I’ve edited server.properties to point to the correct IP address and setup settings.ini in Phoebus to point to the alarm server. Additionally, I have added org.phoebus.pv.ca/addr_list to the ini settings and set auto addr_list to false.
Does anyone happen to have experience with this issue? In case it helps, I’ve seen it happen mostly with IOCs that interface with hardware.
Sincerely,
Dhruv Srinivas
Sincerely,
Dhruv Srinivas
Prev: Channel Finder Recsync Server issue Sandeep Kumar Malu - STFC UKRI via Tech-talk
Next: RE: Use PV value as a macro definition when opening a display CHOQUET Antoine via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Prev: Re: Channel Finder Recsync Server issue Sandeep Kumar Malu - STFC UKRI via Tech-talk
Next: ADURL failing to open specific URL Marco Filho via Tech-talk
ANJ, 11 Sep 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
