Hi Marco,
I’ll try to help if I can.
I’m not familiar with Hikivision cameras, and I’ve never tested the module with one.
Questions:
Do you get any image frames at all, using ADURL?
Are you able to use a web browser to view the camera? Does it re-direct if you do so?
Does the camera operate in single-frame mode (you have to press F5 in a web browser to get another image) or does it operate in streaming mode?
Cheers,
Peter.
This message contains information that may be privileged or confidential and is the property of the Capgemini Group. It is intended only for the person to whom it is addressed. If you are not the intended recipient, you are not authorized to read, print, retain, copy, disseminate, distribute, or use this message or any part thereof. If you receive this message in error, please notify the sender immediately and delete all copies of this message.
Re: ADURL failing to open specific URL Ralph Lange via Tech-talk
Re: Channel Finder Recsync Server issue Sandeep Kumar Malu - STFC UKRI via Tech-talk
<2024>
2025
Phoebus and React Automation Studio comparison Kuldeep Joshi via Tech-talk
<2024>
2025
ANJ, 11 Sep 2024 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
