Subject: |
Re: Storing passwords in records/Authenticating IOC with other servers |
"Johnson, Andrew N. via Tech-talk" <[email protected]> |
To: |
"Yendell, Gary (DLSLtd,RAL,LSCI)" <[email protected]>, 'Marco Filho' <[email protected]>, "[email protected]" <[email protected]>, "Akeroyd, Freddie (STFC,RAL,ISIS)" <[email protected]> |
Date: |
Fri, 19 Jul 2024 16:40:17 +0000 |
Yes, so you'd also need to set up access security as well, to limit who has read access to that record. You'd need to know that it's trivial to spoof the CA user-name, and turn on the setting which makes the
IOC check the IP address of the client instead of believing the host-name it provides. Some CA clients might not behave terribly well when pointed at an unreadable record (that's not a situation many client developers even think about let alone test), and
I don't know whether any clients or the IOC have ever been tested with a record that's writable but not readable (never tried that). I think the PVA protocol dropped support for unreadable channels, but I could be wrong about that.
The CA protocol isn't cryptographically secure and never will be, although future versions of the PVXS and Java PVA implementations may be. That means it might be possible for anyone who has access to the
wire to snoop the password from a CA put message. Never use an open network for EPICS CA traffic, and even the future PVA versions which rely on TLS could have bugs that make them less secure than the https protocol.
- Andrew
Wouldn't a camonitor show MY_RECORD change to the password and back again with this?
CAUTION: This email is from outside of the organisation and has a suspicious subject or content.
This might likely be a phishing email. Do not click links or open attachments unless you recognise the sender and know the content is safe. If in doubt, contact IT Helpdesk.
Hi, does something like
record(stringout, "MY_RECORD")
field(DTYP, "asynOctetWrite")
field(OUT, "@asyn( … )")
field(FLNK, "MY_RECORD_RESET")
record(stringout, "MY_RECORD_RESET")
field(VAL, "")
field(OUT, "MY_RECORD NPP")
Work? The linked “MY_RECORD NPP” should clear the initial record value without processing it again (so not sending a blank password to asyn)
Freddie
On Behalf Of Marco Filho via Tech-talk
Sent: Friday, July 19, 2024 3:55 PM
To: [email protected]
Subject: Storing passwords in records/Authenticating IOC with other servers
Hi, all
I am creating an epics ADDriver that needs to communicate and authenticate with another server. The authentication requires a password and a username.
Since I want everything to be as dynamic as possible, I wanted to create a record to use the password to authenticate, but I don't feel comfortable only protecting the record with ASG because it feels like a thin layer of protection.
I tried making an asynOctetWrite record that passes a value to MYDriver::writeOctet() without storing the value passed. In other words: something that would behave like:
caput MY_RECORD PASS
(Function MYDriver::writeOctet gets called with PASS passed as an argument to the function)
caget MY_RECORD
MY_RECORD #Shows nothing, nothing is actually stored in the record.
But I could not succeed in making this record only with asyn. The best solution I can think of now is reading the password from a file which again doesn't seem like the optimal solution.
This is probably not a too specific problem, so I'm wondering if there is already any elegant solution for that? Can anyone think of a better approach? Or maybe an already-existing record that does something similar?
Thanks for any suggestions,
Marco
This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient
of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail. Any opinions expressed within this e-mail are those of the individual and not necessarily
of Diamond Light Source Ltd.
Diamond Light Source Limited (company no. 4375679). Registered in England and Wales with its registered office at Diamond House, Harwell Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom.
- Re: Storing passwords in records/Authenticating IOC with other servers Ralph Lange via Tech-talk
- Storing passwords in records/Authenticating IOC with other servers Marco Filho via Tech-talk
- RE: Storing passwords in records/Authenticating IOC with other servers Freddie Akeroyd - STFC UKRI via Tech-talk
- Re: Storing passwords in records/Authenticating IOC with other servers Yendell, Gary (DLSLtd, RAL, LSCI) via Tech-talk
<2024>
2025
2026
<2024>
2025
2026
