1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: Asyn or Stream device interface for struct data
From: Zimoch Dirk via Tech-talk <[email protected]>
To: Abdalla Ahmad <[email protected]>
Date: Thu, 5 Sep 2024 08:58:38 +0000
Hello Abdalla
Yes, you can do this using the %r format together with redirection in order to split the values into 4 records or combing the data from them. As your communication does not use terminators but has a fixed data size, use MaxInput.
You need to know how the exact struct layout will look like on the network, in particular what the byte order is and if there will be "gaps" due to alignment. The compiler will probably add 2 bytes gap before u32 data when mapping this structure to memory in order to align the u32.
Without any gaps:
MaxInput = 10; # total struct size
read {
   in "%(\$1:STATUS)02r%(\$1:COMAND)02r%(\$1:ADDRESS)%04r";
The 0 prefix in %()02r handles the value as unsigned, so that e.g. 0xf000 is not expanded to a negative record value.
I assume here that the data is in big endian byte order. If you have little endian byte order, use the # modifier: %()#02r.
The "\$1" is the first argument to the protocol. Pass the "basename" of your records like this:
record (longin, "$(DEVICE):DATA") {
    field(DTYP, "stream")
    field(INP, "@$(PROTOCOLFILE) read($(DEVICE)) $(PORT)")
record(longin "$(DEVICE):STATUS) {
# the 'status' field will be put here by the read protocol
Maybe you want to use a constant address instead of having it in a record. Pass it as a second parameter:
   field(INP, "@$(PROTOCOLFILE) read($(DEVICE),$(ADDRESS)) $(PORT)")
and then reference it as $2 You need to pass the 16 byte address  as 2 bytes like "00 01" (or maybe only use 1 byte and have a for example fixed 00 upper byte):
    in "%(\$1:STATUS)02r%(\$1:COMAND)02r" $2 "%04r";
Also the command may be fixed. Either pass it as a third argument or have different protocols for different commands:
commandABCD {
    in "%(\$1:STATUS)02r" AB CD $2 "%04r";
This way multiple input records may wait for input with "I/O Intr" scanning and select the matching command (if the device sends on it own without being asked). Or if you have the send a request first and use the command (and address) in both, the out and the in command, the in command will check that it actually gets the correct address.
I am speculating a lot how your protocol actually works. Give me more details if you need a detailed advice.
Dirk
On 5 Sep 2024, at 09:33, Abdalla Ahmad via Tech-talk <[email protected]> wrote:
Hi
We have a device that I am working on a device support for using asynPortDriver, but its interface is very simple, it is basically a simple C struct used for both TX and RX. Something like this:
typedef struct {
     u16 status,
     u16 command,
     u16 address,
     u32 data
} packet_t;
I send this packet and I receive the same packet in the response with the corresponding data. Can such a communication interface be achieved using stream device or asyn support?
Best Regards,
Abdalla.
RE: Asyn or Stream device interface for struct data Abdalla Ahmad via Tech-talk
Prev: Asyn or Stream device interface for struct data Abdalla Ahmad via Tech-talk
Next: RE: Asyn or Stream device interface for struct data Abdalla Ahmad via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
