1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Another question regarding record stringout, lso and Record reference manual in general
From: Heinz Junkes via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Mon, 9 Sep 2024 18:02:39 +0200
I can't find a description in the Record Reference Manual of what ‘DCT’ means.
This is always displayed in the tables:
Stringout Record:
Field Summary Type DCT Default Read Write CA PP
VAL Current Value STRING [40] Yes  Yes Yes Yes
DOL Desired Output Link INLINK Yes  Yes Yes No
OMSL Output Mode Select MENU (menuOmsl) Yes  Yes Yes No
lso record:
VAL Current Value STRING or CHAR[SIZV] No  Yes Yes Yes
SIZV Size of buffers USHORT Yes 41 Yes No No
I'm completely confused about the description of the records. That's probably because we've been trying all afternoon.
E.g. stringout :
"The first field that determines where the desired output originates is the output mode select (OMSL) field, which can have two possible value: closed_loop or supervisory. If supervisory is specified, DOL is ignored, the current value of VAL is written, “
"DOL can also be a constant, in which case VAL will be initialized to the constant value. “
"Note that if DOL is a constant, OMSL cannot be closed_loop.”
Similiar confusion with lso:
"If supervisory is specified, DOL is ignored, "
"DOL can also be a constant instead of a link, in which case VAL is initialized to the constant value. “
Heinz
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: [EXTERNAL] Another question regarding record stringout, lso and Record reference manual in general Hartman, Steven via Tech-talk
Re: [EXTERNAL] Another question regarding record stringout, lso and Record reference manual in general Kasemir, Kay via Tech-talk
Prev: lso record Heinz Junkes via Tech-talk
Next: Re: [EXTERNAL] Another question regarding record stringout, lso and Record reference manual in general Hartman, Steven via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Re: lso record Michael Davidsaver
