1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: [EXTERNAL] lso record
From: "Hartman, Steven via Tech-talk" <[email protected]>
To: Heinz Junkes <[email protected]>
Date: Mon, 9 Sep 2024 16:27:38 +0000
This works . . .
record(lso, "myLSO")
   field(DOL, {const:"foo"})
Steven Hartman
On Sep 9, 2024, at 11:44 AM, Heinz Junkes via Tech-talk <[email protected]> wrote:
Good evening,
I have a problem with the lso (long string out) record.
When I use it as a replacement for stringout (limited to 41 char),
according to the Record reference Manual : "To initialize a string output record it is simplest to set the VAL field directly"
record(lso, "$(user):zone0")
   field(VAL, 'blabberblabberblub')
I get the following message:
dbLoadRecords "db/tempLinuxExample.db", "user=ares"
Can't set "ares:zone0.VAL" to "blabberblabberblub"  : Bad Field value
ERROR:  at or before ')' in file "db/tempLinuxExample.db" line 7
7 |     field(VAL, 'blabberblabberblub')
ERROR failed to load 'db/tempLinuxExample.db’
We then tried the contradictory definitions of the description:
"DOL can also be a constant instead of a link, in which case VAL is initialized to the constant value.”
   field(DOL, 'blabberblabberblub')
epics@ares:~$ caget -s ares:zone0.VAL$
ares:zone0.VAL$ 41 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
But I don't quite understand this:
"The first field that determines where the desired output originates is the output mode select (OMSL) field, which can have two possible values: closed_loop or supervisory. If closed_loop is specified, the VAL field's value is fetched from the address specified in the Desired Output Link field (DOL) which can be either a database link or a channel access link. If supervisory is specified, DOL is ignored, “
   field(OMSL, "closed_loop")
The same output :
Danke Heinz
Re: [EXTERNAL] lso record Heinz Junkes via Tech-talk
Prev: Re: [EXTERNAL] Another question regarding record stringout, lso and Record reference manual in general Kasemir, Kay via Tech-talk
Next: Re: lso record Rolf Keitel via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: lso record Heinz Junkes via Tech-talk
Next: Re: [EXTERNAL] lso record Heinz Junkes via Tech-talk
