1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Subject: Using alternative build systems (meson) for IOCs/modules
From: Érico Nogueira Rolim via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 24 Sep 2024 15:29:02 +0000
Hi!
I'm currently considering how to unify building an IOC [1] and one of
its dependencies [2], which uses Meson. I am struggling somewhat to come
up with a proper directory structure and rules to make that happen, but
it occurred to me that this would be much simpler if IOCs were built
with Meson instead of Make.
There is a PR to PVXS to enable building it with Meson instead of the
EPICS build system [3]. It depends on a change to epics-base that hasn't
been merged yet, and I don't know what its status in PVXS is. Is it
simply waiting for the changes to epics-base, or are there outstanding
issues and/or objections to the proposal?
Were that to be merged, would a possible future direction be to support
a Meson-based template for IOCs (and possibly modules)? It might help
simplify a lot of workflows and decrease the burden of debugging the
build system, since meson allows customization in a more standardized way.
Cheers,
Érico
[1] https://urldefense.us/v3/__https://github.com/lnls-dig/afc-epics-ioc__;!!G_uCfscf7eWS!fFOFfChCZcTfs77aILKh3aDnMxyceIvNb-5yJMQL8utT8U74DGLf6WvkumAyw74306kw1cKMzpHFemSkCJDekExWOes$
[2] https://urldefense.us/v3/__https://github.com/lnls-dig/uhal__;!!G_uCfscf7eWS!fFOFfChCZcTfs77aILKh3aDnMxyceIvNb-5yJMQL8utT8U74DGLf6WvkumAyw74306kw1cKMzpHFemSkCJDeyNfTunA$
[3] https://urldefense.us/v3/__https://github.com/epics-base/pvxs/pull/35__;!!G_uCfscf7eWS!fFOFfChCZcTfs77aILKh3aDnMxyceIvNb-5yJMQL8utT8U74DGLf6WvkumAyw74306kw1cKMzpHFemSkCJDexmsr2iE$
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: Using alternative build systems (meson) for IOCs/modules NICOLE Rémi via Tech-talk
Prev: Writing XML directly to area detector's NDAttributesFile PV Wolfman, Mark via Tech-talk
Next: Re: Writing XML directly to area detector's NDAttributesFile PV Érico Nogueira Rolim via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Prev: Re: Writing XML directly to area detector's NDAttributesFile PV Wolfman, Mark via Tech-talk
Next: Re: Using alternative build systems (meson) for IOCs/modules NICOLE Rémi via Tech-talk
ANJ, 27 Sep 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
