1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: RE: archive appliance some PVs no data
Date: Wed, 25 Sep 2024 07:34:23 +0000
Hi all,
I agree with Michael. This would be a per PV setting, as you would only want this feature for those PVs on particular IOCs where the timestamp is funky. It would also make the timestamp logic very unintuitive.
Some other notes,
  • The timestamp of the event in an IOC can be totally different to the host machine time of the IOC. You might be taking the timestamp from some other source like a timing system.
  • The timestamp in the archiver is the time at which the event is received by the archiver, which is not at all when the event happened in the IOC. If your network is flaky and you drop lots of packets for instance, there could be a big delay for when the event is received.
Nonetheless, if you want to add this feature, develop it and make a pull request and we can figure out how to cleanly fit it in.
Best regards,
Sky
Prev: Re: Simple CAN bus over ethernet interface Florian Feldbauer via Tech-talk
Next: Re: Writing XML directly to area detector's NDAttributesFile PV Wolfman, Mark via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: RE: archive appliance some PVs no data Abdalla Ahmad via Tech-talk
Next: FLIR SpinView on alma 9? John Dobbins via Tech-talk
