Subject: |
Re: Asyn + Streamdevice: Gamma Vacuum Digtial QPC, missmatch after some time |
"Dr. Simon Friederich via Tech-talk" <[email protected]> |
To: |
Date: |
Mon, 14 Oct 2024 12:33:13 +0200 |
Maybe one follow-up
question:
Are these error
messages from ASYN or from IOC itself?
Can I retrieve these
errors also in my iocLog?
Best regards
Simon
Am 14.10.2024 um 12:19 schrieb Dr.
Simon Friederich:
Dear Ralph and Marco,
Your argumentation
sounds reasonable. Thank you for the advice, I'll give Marco's
replytimeout a try :-)
(regardless of
whether this solution works for me, this sounds like something
that could be collected on a tips & tricks subpage of https://epics-controls.org/
Best regards,
Simon
Am 14.10.2024 um 11:30 schrieb Dr.
Simon Friederich:
Dear
EPICS-community,
I am struggeling
with our implementation of the IGP controller from Gamma
Vacuum Digital QPC that we use.
Out of the sudden or at a certain point, which I can neither
explain nor reproduce, the IOC complains that the
controllers' responses to the protocol no longer fit.
Here is an example
output that I've retrieved in the morning, before that the
IOC ran for weeks without error:
2024/10/08 08:15:41.970931 igpctrlmodh2071_port
melba060:pump:i_get_raw: No reply within 2000 ms to "cmd 0A
1<0d>"
2024/10/08 08:15:43.974231 igpctrlmodh2071_port
melba060:pump:p_get_raw: No reply within 2000 ms to "cmd 0B
1<0d>"
2024/10/08 08:15:45.977001 igpctrlmodh2071_port
melba060:pump:u_get: No reply within 2000 ms to "cmd 0C
1<0d>"
2024/10/08 08:15:46.722205 igpctrlmodh2071_port
melba040:diffp_down:on_get: Input "1.3E-11 MBAR" does not
match format "%{NO|YES}"
2024/10/08 08:15:46.842189 igpctrlmodh2071_port
melba060:pump:stat_get: Input "13" does not match format
"%{STANDBY|RUNNING 00|SAFE-CONN 00|INTERLOCK 00|PUMP ERROR
00|CALIBRATION 00}"
2024/10/08 08:15:46.967906 igpctrlmodh2071_port
melba040:diffp_down:stat_get: Input "18" does not match format
00|CALIBRATION 00}"
2024/10/08 08:15:47.087939 igpctrlmodh2071_port
melba040:diffp_down:i_get_raw: Input "NO" does not match
format "%e"
2024/10/08 08:15:47.207884 igpctrlmodh2071_port
melba040:diffp_down:p_get_raw: Input "STANDBY" does not match
format "%e"
2024/10/08 08:15:47.327939 igpctrlmodh2071_port
melba060:pump:on_get: Input "PUMP ERROR 00" does not match
format "%{NO|YES}"
2024/10/08 08:15:47.693674 igpctrlmodh2071_port
melba060:pump:u_get: Input "NO" does not match format "%i"
2024/10/08 08:15:48.059375 igpctrlmodh2071_port
melba040:diffp_down:i_get_raw: Input "OK 00 14" too short.
2024/10/08 08:15:48.059449 igpctrlmodh2071_port No match for "
AMPS"
2024/10/08 08:15:48.179663 igpctrlmodh2071_port
melba040:diffp_down:p_get_raw: Input "OK 00 7.5E-11 AMPS"
2024/10/08 08:15:48.179734 igpctrlmodh2071_port
melba040:diffp_down:p_get_raw: mismatch after 14 bytes "...0
7.5E-11 "
2024/10/08 08:15:48.179764 igpctrlmodh2071_port
melba040:diffp_down:p_get_raw: got "AMPS" where "MBAR" was
expected
2024/10/08 08:15:48.299339 igpctrlmodh2071_port
melba060:pump:on_get: Input "1.3E-11 MBAR" does not match
format "%{NO|YES}"
2024/10/08 08:15:48.419330 igpctrlmodh2071_port
melba060:pump:i_get_raw: Input "NO" does not match format "%e"
2024/10/08 08:15:48.545033 igpctrlmodh2071_port
melba060:pump:p_get_raw: Input "OK 00 1.9E-10 AMPS"
2024/10/08 08:15:48.545094 igpctrlmodh2071_port
melba060:pump:p_get_raw: mismatch after 14 bytes "...0 1.9E-10
2024/10/08 08:15:48.545132 igpctrlmodh2071_port
melba060:pump:p_get_raw: got "AMPS" where "MBAR" was expected
2024/10/08 08:16:35.567653 igpctrlmodh2071_port
melba040:diffp_down:p_get_raw: No reply within 2000 ms to "cmd
0B 3<0d>"
2024/10/08 08:16:36.821755 igpctrlmodh2071_port
format "%{NO|YES}"
I attach the proto
and database files we've written. Maybe you can spot any
obvious error or have any advice for me to further debug
this issue.
Best regards,
Simon
Institut für Kernphysik
Kollaboration B | MESA
Johannes Gutenberg-Universität Mainz
Johann-Joachim-Becher-Weg 45
D 55128 Mainz
Tel.: +49 (0)6131 39-23160
E-Mail: [email protected]
- RE: Asyn + Streamdevice: Gamma Vacuum Digtial QPC, missmatch after some time Mark Rivers via Tech-talk
- Asyn + Streamdevice: Gamma Vacuum Digtial QPC, missmatch after some time Dr. Simon Friederich via Tech-talk
- Re: Asyn + Streamdevice: Gamma Vacuum Digtial QPC, missmatch after some time Dr. Simon Friederich via Tech-talk
Re: Phoebus Olog and Web Client Dr. Simon Friederich via Tech-talk
<2024>
2025
2026
<2024>
2025
2026
