1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: Procserv execute error
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Fri, 1 Nov 2024 10:34:50 +0100
Hi Baeg,
As the root error is "No such file or directory", this looks like a problem related to the file system and/or permissions.
Make sure:
- the child directory setting has no typos, the directory exists, is readable and executable for the user that runs procServ
- the startup script setting has no typo, the script exists in that directory, is readable and executable for the user that runs procServ
You seem to be running procServ as root. However, root has only anonymous access (user "nobody") to NFS-mounted directories.
If your IOC structure is on NFS, it might be easier to run procServ as a different user who you can give access to the NFS mount through group membership.
(If you want access for root, you need to make things readable/executable for everyone, which might be a security issue.)
Cheers,
~Ralph
Procserv execute error 백호령 via Tech-talk
Prev: Procserv execute error 백호령 via Tech-talk
Next: Re: pasynOctetSyncIO->read() weirdly slow performance Marco Filho via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Next: Re: Procserv execute error Mark Rivers via Tech-talk
