Dear all,
I’m trying to install a recent EPICS Archiver Appliance (Version 2.0.5) using the install script like it is described in the docs:
https://epicsarchiver.readthedocs.io/en/latest/sysadmin/installguide.html#using-an-install-script
My system is an OpenSuSe – Leap 15.6 and the archiver installation should be the only one in the cluster / on the machine.
The install script, and the deployRelease.sh afterwards, both finish without errors.
However, when I start the archiver appliance via the sampleStartup.sh script, I get the following error in the log files of engine, etl, mgmt and retrieval:
2024-10-30 15:50:49,117 FATAL [main] config.DefaultConfigService (DefaultConfigService.java:293) - Exception loading the appliance properties file
I have an older archiver running version 1.1.0 on another machine. I also used the install script to install it. Looking into the folders:
…/engine/webapps/engine/WEB-INF/classes
…/etl/webapps/etl/WEB-INF/classes
…/mgmt/webapps/mgmt/WEB-INF/classes
…/retrieval/webapps/retrieval/WEB-INF/classes
I found the five files: appliances.xml; archappl.properties; failover_dest.xml; failover_other.xml and policies.py
By simply copying them into the same locations of my new archiver, it resolved the problem: the new archiver is starting.
I don’t remember making these files manually in the old installation.
Why are these files missing in the new installation? Did I forgot to set some settings before running the install script?
Best regards
Michael
Michael Sintschuk
Bundesanstalt für Materialforschung und –prüfung (BAM)
8.5 - X-ray Imaging
Unter den Eichen 87
12205 Berlin
GERMANY
P: +49 30 8062-15063 (BESSY, Adlershof)
michael.sintschuk at bam.de
