1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: [EXTERNAL] Re: IOC Shell Persist history: ERROR Permission denied (13) writing '.iocsh_history'
From: "Webb, Brad via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "Johnson, Andrew N." <[email protected]>
Date: Fri, 1 Nov 2024 20:37:59 +0000
Thanks Andrew.
I was thinking that this type of thing should be set using:
epicsEnvSet()
-Brad
On Fri, 2024-11-01 at 19:51 +0000, Johnson, Andrew N. wrote:
> At APS our production IOCs are started from a script with the CWD set to the IOC‘s boot directory.
> The accounts they run under deliberately have no ability to write to their own application or
> configuration files, in an attempt to make it harder for anyone who successfully breaks into one
> to persistently change those files.
> Brad didn’t say so, but I assume SNS also use read-only IOC boot directories. I guess he could
> give procServ the command
>     /bin/env EPICS_IOCSH_HISTFILE=/path… ./st.cmd
> to start the IOC without having to wrap it in a script, although that feels a bit unwieldy to me.
> I already added setting that environment variable to our IOC launch script, even though we aren’t
> running 7.0.8.1 yet.
> - Andrew
> Complexity comes for free, Simplicity you have to work for.
> On 11/1/24, 1:26 PM, "Tech-talk" <[email protected]> wrote:
> On 11/1/24 06:09, Webb, Brad via Tech-talk wrote:
> > After upgrading to EPICS 7.0.8.1 I see the errors below in the IOC start-up console output.
> >   From the release notes:
> > https://urldefense.us/v3/__https://github.com/epics-base/epics-base/blob/7.0/documentation/RELEASE_NOTES.md*persist-history__;Iw!!G_uCfscf7eWS!fxC6WWyvShbxHs8jPNfGxcc-Yd3gb7wGySPtGjoGKon5HqQERrpNd3FD4NrQvKubT7JRig5xbohNUi8W3jbS$
> > I find this section about setting the environment variable:
> > Persist history
> > Attempt to read and write command to a file (./.iocsh_history by default). Name may be
> > overwritten
> > with by setting $EPICS_IOCSH_HISTFILE to an alternate path, or disabled by setting to an empty
> > string.
> > So, my question is how can this variable be set on a per IOC basis so that each IOC can have its
> > own
> > unique path for the history file?
> Whatever mechanism you are using to launch IOC processes would
> need to compute and set $EPICS_IOCSH_HISTFILE .
> Since you did RtM, I appreciate that this is not by itself a
> useful reply :)
> Can you say more about how your IOCs are being launched?
> Do multiple IOC processes share the same $PWD and/or does
> an IOC not have permission to create files in $PWD ?
IOC Shell Persist history: ERROR Permission denied (13) writing '.iocsh_history' Webb, Brad via Tech-talk
Re: IOC Shell Persist history: ERROR Permission denied (13) writing '.iocsh_history' Michael Davidsaver via Tech-talk
Re: IOC Shell Persist history: ERROR Permission denied (13) writing '.iocsh_history' Johnson, Andrew N. via Tech-talk
Prev: Re: IOC Shell Persist history: ERROR Permission denied (13) writing '.iocsh_history' Johnson, Andrew N. via Tech-talk
Next: Re: IOC Shell Persist history: ERROR Permission denied (13) writing '.iocsh_history' Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
