Hi Abdallah,
UDP and TCP use the same port number, not just the same IP address and physical port? I don't think I have run into that before, so I can't see whether it has been tested with asyn. You can turn on asynTrace on each port, and send them to different files
to see if there are issues.
Hi
I am writing an EPICS driver for an Ethernet-based device in which the control interface is split between TCP and UDP layers of the same port number (i.e., registers IO is through UDP while waveforms is through
TCP). I have to create two asyn ports using drvAsynIPPortConfigure function, so my question is are there any consideration regarding this approach? Because I am noticing some timeout issues, most likely from the device’s side, so I want to narrow the issue
as much as I can. Thanks in advance.
Best Regards,
Abdalla Al-Dalleh
Control Engineer
SESAME
P.O. Box 7, Allan 19252, Jordan
Tel: +96253511348 , ext. 265
Fax: +96253511423
Email :
[email protected]
Website: www.sesame.org.jo
- RE: Multiple asyn ports inside asynPortDriver class Abdalla Ahmad via Tech-talk
- Multiple asyn ports inside asynPortDriver class Abdalla Ahmad via Tech-talk
Asyn device support does not reconnect Miroslaw Dach via Tech-talk
<2024>
2025
2026
<2024>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
