1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: RE: Asyn device support does not reconnect
To: Miroslaw Dach <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Thu, 7 Nov 2024 18:42:16 +0000
Hi Mirek,
  • 1. Galil (Galil-4-0-02) motion controller driver. When the connection is lost it reconnects and crashes straight after with the message:
I am using Galil 3-6 and I don’t see this problem with my DMC-4183 controllers.  When I power-cycle the controller the IOC reconnects with no problem.  These are the messages I see when I power it off for about 10 seconds.
Disconnected from DMC4183 Rev 1.3k at 10.54.160.161
2024/11/07 12:33:43.977 GALILSYNC2 -1 autoConnect could not connect: Can't connect to 10.54.160.161:23 TCP: No route to host
Connected to DMC4183 Rev 1.3k at 10.54.160.161
Code started successfully on model DMC4183 Rev 1.3k, address 10.54.160.161
  • 2. Vimba ccd camera driver simply does not reconnect when the connection with the camera  is lost.
That is an issue that we should look at for ADVimba, ADSpinnaker, and other areaDetector drivers with Ethernet connections.  It would be nice to solve it in a centralized place, perhaps in ADGenICam.
  • 3. Custom stream device support driver which uses the call:
  • drvAsynIPPortConfigure("custom_device", "HW_dev:8003",0,0,0)
  • The ioc does not reconnect when the underlying hardware is off for a longer time (2-3 hours) and powered back.
Have you added this line to your startup script?
asynSetOption("custom_device", 0, "disconnectOnReadTimeout", "Y")
That will close the socket on the IOC when there is a timeout.  If autoConnect is true, then it will then continuously attempt to reconnect every few seconds.
From: Tech-talk <[email protected]> On Behalf Of Miroslaw Dach via Tech-talk
Sent: Thursday, November 7, 2024 12:02 PM
To: EPICS Tech-Talk <[email protected]>
Subject: Asyn device support does not reconnect
Hi All,
We are using in ALS various drivers which are based on Asyn.
Some of them do not auto reconnect. I wanted to consult with you
what could be done in order to make them auto reconnect.
free(): invalid size
or
munmap_chunk(): invalid pointer
example:
Disconnected from DMC4040 Rev 1.3i-SER at 131.243.196.71
connected_=1
Connected to DMC4040 Rev 1.3i-SER at 131.243.196.71
connected set false
2024/10/30 15:17:58.330 GALILSYNC0 -1 autoConnect could not connect: Can't connect to 131.243.196.71:23 TCP: Connection timed out
2024/10/30 15:20:09.411 GALILSYNC0 -1 port is now connected
connected_=1
Aborted (core dumped)
We use the driver for the Manta G-235B camera (with the Allied Vision 1800 U-501 NIR  cheap) and also older cameras Manta_G-145 . We used before the Prosilica driver what was doing the auto connect but Vimba does not do that.
Best Regards
Mirek
Re: Asyn device support does not reconnect Miroslaw Dach via Tech-talk
Prev: Asyn device support does not reconnect Miroslaw Dach via Tech-talk
Next: RE: Error "drvModbusAsyn::readPoller ... invalud memory request 3, max=3" of module Eurotherm2k Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Next: Re: Asyn device support does not reconnect Miroslaw Dach via Tech-talk
