1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Subject: Re: IOClog
From: Saisrikiran Mudigonda via Tech-talk <tech-talk at aps.anl.gov>
To: Dale Cox <dale.cox at acu.edu>
Cc: EPICS Tech-Talk <tech-talk at aps.anl.gov>
Date: Fri, 8 Nov 2024 10:24:52 +0530
At EPIC, we log different types of errors to log files using procServ. Error logs, Console logs, CaPut logs and Server logs are the types of logs we capture. We push the logs to a central server using NFS share.
For analytics, we use Grafana dashboards. We use Elastic search to process the logs ingested from Logstash. We also use "tags" to differentiate between errors (db_error, connection_error, etc.) in the logstash pipeline.
For capturing the status of the servers, we use Prometheus with Node_exporter and Blackbox_exporter for the health (UP/DOWN status) of the servers.
We also show the number of IOCs up/down using "node_systemd_unit_state" of Node_exporter (as each IOC runs as a systemd service).
Our dashboard is distributed in 3 panels - first panel contains IOC count (server1, server2, etc), second panel contains Hardware errors and the third panel has IOC errors.
The IOC errors are captured using keywords like ERROR, etc. and using "tags".
Best Regards,
Sai
Project Software Engineer
Extreme Photonics Innovation Centre
TIFR, Hyderabad, India
On Fri, Nov 8, 2024 at 2:33 AM Dale Cox via Tech-talk <tech-talk at aps.anl.gov> wrote:
At NEXTLab, we use rsyslog to ship the logs out to a remote server.  I was looking for more than just the IOC errors that come across the error log.  We log all of the console output to a log file, then use rsyslog to send that to a central log storage server for review later.
For reviewing/analytics, we use Grafana.  To get the data into a datasource so grafana can show it, we use a pipeline of Promtail > Loki running on the log server.  It works well, and if you set your dashboard up right, you can do searches and analytics pretty easily.
It also pairs with other grafana-focused tools like Prometheus.  We can run the node-exporter on our IOC machines and view the logs alongside hardware stats like CPU / RAM usage, etc.
This workflow has made me want to start logging other stuff to that same location.
It's great that there are so many IT-centric tools out there that have solved a lot of this.
Dale
On Thu, Nov 7, 2024 at 2:18 PM Miroslaw Dach via Tech-talk <tech-talk at aps.anl.gov> wrote:
Hi All,
We have experimented with logstash and we have the environment setup for caput log and error messages setup.
All seems to work fine when saving datas into the logfiles.
The configuration for logstash which Andrew has summarised:
https://events01.synchrotron.org.au/event/85/contributions/2601/attachments/689/997/5_06_Logstash_for_IOCs.pdf
was very helpful.
Do you have a similar summary for elastic search and Kibana configuration?
Best Regards
Mirek
Subject: Re: IOClog
From: "Konrad, Martin via Tech-talk" <tech-talk at aps.anl.gov>
To: Neil Hamilton Jr <neil.hamilton.jr at gmail.com>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 2 May 2019 13:36:10 +0000
Hi Neil,
> Is the recommended logging facility IOClog?
20 years ago it was a good choice. If you are looking for a simple
solution for testing it might still get the job done.
For production use there are more powerful tools around, though. Some
labs including ANL and FRIB are successfully using Logstash now which is
very popular in the IT world (there is a good chance your sysadmin is
already using it for system log files etc.). You might want to consider
pairing Logstash with the Elastic Stack to allow fast search and Kibana
for visualization. Andrews had a few slides about how to configure it to
receive EPICS log messages:
Unfortunately, we didn't find time to document this properly. We
appreciate your help turning Andrews slides into a description that can
go into our official documentation.
Martin
Dale Cox
Instrumentation and Electrical Engineer
ACU NEXT Lab
Re: IOClog Miroslaw Dach via Tech-talk
Re: IOClog Dale Cox via Tech-talk
Prev: Re: Error "drvModbusAsyn::readPoller ... invalud memory request 3, max=3" of module Eurotherm2k LiangChih Chiang via Tech-talk
Next: FW: Review of submission for new QuadEM Iain Marcuson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Prev: Re: IOClog Dale Cox via Tech-talk
Next: Very stange compile error on Windows Mark Rivers via Tech-talk
ANJ, 11 Nov 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
