I was applying the prefix and have used the border feature. Kay's insight that only certain objects follow the preference clears up why it didn't work as I expected.
Michael is correct on the settings file syntax.
Still, note that those colors aren’t for everything that you might have in mind.
The alarm table, probe, PV table use these settings that you mention.
For the display builder, the “alarm sensitive” behavior is handled via a border around the widget, see
https://github.com/ControlSystemStudio/phoebus/wiki/Display-Builder-Compatibility#alarm-indication
On 11/11/24 16:45, Paul Sichta via Tech-talk wrote:
> I have added the preferences below in my settings.ini file. I expected the text color to change based on alarm sevr but it just stays the same (the color selected for the text update object) .
> excerpt from preferences listing:
> # Color for text and the background for 'OK' alarm severity (R,G,B or R,G,B,A values in range 0..255)
> ok_severity_text_color=0,255,0
> ok_severity_background_color=255,255,255
> # Color for text and the background for 'MINOR' alarm severity
> minor_severity_text_color=255,128,0
The way the phoebus settings.ini files are structured is always:
> package.name/preference_name=value
So there will _always_ be a '/' somewhere.
Parsing this from the documentation is a confusing...
https://urldefense.us/v3/__https://control-system-studio.readthedocs.io/en/latest/preference_properties.html__;!!G_uCfscf7eWS!bKdm6KbqSxWqXdi3twX47I9pcd1wJIFNMLKAtNnPI6PFr5B8cuVZsqQd0R0j-1mfa8WBgzTK2ASVnfBOfeUku9ZTaw$
the section you quote is preceded by:
> File ../../core/ui/src/main/resources/phoebus_ui_preferences.properties:
> # Package org.phoebus.ui
So the full name of eg. 'ok_severity_text_color' as it should appear in settings.ini is:
> org.phoebus.ui/ok_severity_text_color=0,255,0
- Phoebus: text color based on alarm severity Paul Sichta via Tech-talk
- Re: Phoebus: text color based on alarm severity Michael Davidsaver via Tech-talk
- Re: [EXTERNAL] Re: Phoebus: text color based on alarm severity Kasemir, Kay via Tech-talk
Re: [EXTERNAL] Phoebus settings.ini - Path to predefined Colors and Fonts Kasemir, Kay via Tech-talk
<2024>
2025
2026
Phoebus settings.ini - Path to predefined Colors and Fonts Dr. Simon Friederich via Tech-talk
<2024>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
