1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Re: adl2ui segmentation fault - Needs contacts for CaQTDM development
From: Brands Helge via Tech-talk <[email protected]>
Date: Thu, 28 Nov 2024 09:49:26 +0000
Hi all,
caQtDM is maintained by me ([email protected]).
The best way to create an issue is to open an issue on (https://github.com/caqtdm/caqtdm)
General development information:
We have 3 main branches and feature development area:
Master: here we have the lasts stable published version
Release: here we are doing the release work 99% of the changes here belong to MSI, RPM and other packing work. We try avoid here code changes to caQtDM code, but it’s not always possible
Development: main development
 Feature/*: new stuff that could break stuff.
Tagging (https://git-scm.com/book/en/v2/Git-Basics-Tagging): the release candidates will be tested from operation in all PSI accelerators.
Release frequency: as it is needed, but I try to do a new version at the end of a year.
Best regards
                Helge
Prev: RE: EPICS support for SAES NEG POWER pump controller Dr. Simon Friederich via Tech-talk
Next: Windows path syntax problem Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Prev: adl2ui segmentation fault - Needs contacts for CaQTDM development Thorne, Keith (Keith) via Tech-talk
Next: autoConnect could not connect when reading a register by modbus relative addressing 沈治邦 via Tech-talk
