True, but I don't know why the delay helps and don't have a lot of spare time to work on something that only affects the edit mode of MEDM. If someone wants to suggest a proper fix, then I am willing to test it and update the official release. Maybe over the
holiday break I can look into this further.
--Bob
Sent: Monday, December 9, 2024 10:10 AM
To: Soliday, Robert T. <soliday at anl.gov>
Cc: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>; Huang, Rong <ronghuang at ls-cat.org>
Subject: Re: medm edit mode SIGSEGV core dump Ubuntu 24.04.
On 12/06, Soliday, Robert T. via Tech-talk wrote: > I was able to duplicate the problem with MEDM in edit mode on Ubuntu 24. 04 and verified that your source code change is an effective workaround. I have updated our Github release to include
ZjQcmQRYFpfptBannerStart
This Message Is From an External Sender
This message came from outside your organization.
ZjQcmQRYFpfptBannerEnd
> I was able to duplicate the problem with MEDM in edit mode on Ubuntu 24.04 and verified that your source code change is an effective workaround. I have updated our Github release to include this fix.
Wouldn't it be better to actually understand the problem instead of
committing workarounds that add delays? I think this should have a
source code comment saying why the delay is there. Also, the commit
message has no indication of why the delay is needed.
Lewis
- medm edit mode SIGSEGV core dump Ubuntu 24.04. Rong Huang via Tech-talk
- Re: medm edit mode SIGSEGV core dump Ubuntu 24.04. Soliday, Robert T. via Tech-talk
- Re: medm edit mode SIGSEGV core dump Ubuntu 24.04. J. Lewis Muir via Tech-talk
Re: Aerotech Automation1 motor questions Peterson, Kevin M. via Tech-talk
<2024>
2025
Java Status? Kim Gillies via Tech-talk
<2024>
2025
ANJ, 09 Dec 2024 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
