The VMAX field is only used by the motor record to limit the VELO field; the VMAX field is never sent to the controller. Setting VMAX to zero should simply disable the limiting of the VELO field in the motor record.
What is the amplitude of the encoder oscillation while the motor is idle? How does that amplitude compare to the MRES?
Kevin
Sent: Monday, January 6, 2025 9:14 AM
To: Peterson, Kevin M.; tech-talk at aps.anl.gov
Subject: Re: brushless dc motor MRES IS N/A
Hi Kevin, Hi Kevin, I used the ACS motion controller software to move the motors to their target positions successfully. However, after configuring the EPICS substitution files with the following parameters: bash Copy code {N, M, DTYP, PORT,
ZjQcmQRYFpfptBannerStart
This Message Is From an External Sender
This message came from outside your organization.
ZjQcmQRYFpfptBannerEnd
Hi Kevin,
Hi Kevin,
bash
Copy code
{N, M, DTYP, PORT, ADDR, DESC, EGU, DIR, VELO, VBAS, ACCL, BDST, BVEL, BACC, MRES, PREC, DHLM, DLLM, INIT}
# 2.54 mm/rev, 200 steps/rev, 1024 microsteps/step
{1, "m$(N)", "asynMotor", ACS1, 0, "VerY $(N)", mm, Pos, 2.2, 2, 4, 0, 2.2, 4, 9.765625e-07, 4, 400, 0, ""}
I observed that the motor oscillates around the target positions until the retry limit is exceeded. I have attempted adjustments using PID and FRAC settings without success.
Could this issue be related to the VMAX parameter being set to 0? What would be the best approach to resolve this problem?
Best regards,
Alex Tran
Sent: Thursday, December 19, 2024 6:18 PM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>; Tran, Phi Dung <ptran1 at bnl.gov>
There are multiple reasons why the MRES should be set to the ERES for DC brushless motors:
* The MRES, not the ERES, is used by the motor record to convert velocities and accelerations from EGU into controller units
* The MRES, not the ERES, is used to synchronize the raw limit fields with the dial and user limit fields
* The absolute value of the MRES is used as the minimum retry deadband
* The MRES, not the ERES, is used to calculate the raw position to send to the controller when the motor record's dial position is being redefined
* If a user changes UEIP to "No", the motor will still work if MRES == ERES (assuming the motor driver sets both the RMP and REP to the same value)
Kevin
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Tran, Phi Dung via Tech-talk <tech-talk at aps.anl.gov>
Sent: Thursday, December 19, 2024 10:10 AM
Subject: brushless dc motor MRES IS N/A
hI,
I am using a DC brushless motor with an encoder. For the motor record, I will define ERES and set UEIP to YES. That's it; my MRES is not applicable therefore, I will not include this field..
However, experts have advised that I should set MRES equal to ERES. What is the rationale behind this? Is it to ensure that when UEIP is set to NO, the motor still operates correctly?
Alex
- Re: brushless dc motor MRES IS N/A Tran, Phi Dung via Tech-talk
Re: Using Aerotech Automation1 motor controller with EPICS - controller initialization Peterson, Kevin M. via Tech-talk
calcout Record causing crash Jörn Dreyer via Tech-talk
<2025>
RE: brushless dc motor MRES IS N/A Mark Rivers via Tech-talk
Display Builder symbol monitor Vishnu Patel via Tech-talk
<2025>
