1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: MRF kernel modules not seeing hardware
From: "Daykin, Evan via Tech-talk" <[email protected]>
Date: Wed, 29 Jan 2025 15:16:45 +0000
Hello,
On a new linux kernel 6.1.0-30-rt-amd64 installation, I am trying to install the mrfioc2 PCI kernel module by running the following:
sudo make KERNELDIR=/lib/modules/$(uname -r)/build modules_install
make -C /lib/modules/6.1.0-30-rt-amd64/build DRV_VERSION='3' M=/home/daykin/git/mrfioc2/mrmShared/linux modules_install
make[1]: Entering directory '/usr/src/linux-headers-6.1.0-30-rt-amd64'
  INSTALL /lib/modules/6.1.0-30-rt-amd64/extra/mrf.ko
  DEPMOD  /lib/modules/6.1.0-30-rt-amd64
Warning: modules_install: missing 'System.map' file. Skipping depmod.
make[1]: Leaving directory '/usr/src/linux-headers-6.1.0-30-rt-amd64'
depmod -a && modprobe: <no output>
lsmod|grep mrf
mrf                    24576  0
uio                    28672  1 mrf
parport                73728  1 mrf
cat /proc/devices
Character devices:
  1 mem
  4 /dev/vc/0
  4 tty
  4 ttyS
  5 /dev/tty
  5 /dev/console
  5 /dev/ptmx
  7 vcs
10 misc
13 input
29 fb
116 alsa
128 ptm
136 pts
153 spi
180 usb
189 usb_device
226 drm
238 uio
239 aux
240 cec
241 lirc
242 ipmidev
243 watchdog
244 mei
245 nvme-generic
246 nvme
247 cxl
248 bsg
249 ptp
250 pps
251 rtc
252 dax
253 tpm
254 gpiochip
Block devices:
  7 loop
254 device-mapper
259 blkext
sudo dmesg|grep mrf
[  508.671574] mrf: loading out-of-tree module taints kernel.
[  508.671603] mrf: module verification failed: signature and/or required key missing - tainting kernel
I have also tried uninstalling the mrfioc2 version and installing Jukka’s driver (https://github.com/jpietari/mrf-linux-driver) after some small modifications for the deprecation of HAS_UNLOCKED_IOCTL and ioremap_nocache, the module builds successfully but the module_load script also indicates it doesn’t see any EVGs/EVRs.
In both cases, the device files /dev/uio* or /dev/era* are not installed, and the output of lspci is as follows:
sudo lspci -vv -nn -s 07:0f.0
07:0f.0 Signal processing controller [1180]: Micro-Research Finland Oy Device [1a3e:150c] (rev 01)
     Subsystem: Micro-Research Finland Oy Device [1a3e:150c]
     Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
     Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=slow >TAbort+ <TAbort- <MAbort- >SERR- <PERR- INTx-
     Interrupt: pin A routed to IRQ 255
     IOMMU group: 15
     Region 0: Memory at a1000000 (32-bit, non-prefetchable) [disabled] [size=1M]
     Capabilities: [40] Null
sudo lspci -vv -nn -s 07:0e.0
07:0e.0 Signal processing controller [1180]: Micro-Research Finland Oy Device [1a3e:250c] (rev 01)
     Subsystem: Micro-Research Finland Oy Device [1a3e:250c]
     IOMMU group: 15
     Region 0: Memory at a1100000 (32-bit, non-prefetchable) [disabled] [size=1M]
I’ve tried with multiple cards, including some known to be working on older installations and hardware. Is there something I’m missing?
Evan
Re: MRF kernel modules not seeing hardware Shen, Guobao via Tech-talk
Re: MRF kernel modules not seeing hardware Han Lee via Tech-talk
Prev: Re: Archiver Appliance - Limit on PVs Sky Brewer via Tech-talk
Next: Re: MRF kernel modules not seeing hardware Shen, Guobao via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Re: Archiver Appliance - Limit on PVs Shankar, Murali via Tech-talk
