1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: Calc record with two CP input links ending up in inconsistent state
From: Érico Nogueira Rolim via Tech-talk <[email protected]>
To: Michael Davidsaver <[email protected]>
Date: Wed, 19 Feb 2025 11:57:26 +0000
On 17/02/2025 21:15, Michael Davidsaver wrote:
> On 2/17/25 12:54, Érico Nogueira Rolim via Tech-talk wrote:
>> I originally considered that using multiple CP input links would
>> guarantee eventual consistency; was I wrong in this assumption, or is it
>> likely that there is a bug in the record/link implementation?
> What you assume should be true, but indeed there is at least one bug.
> https://urldefense.us/v3/__https://github.com/epics-base/epics-base/issues/557__;!!G_uCfscf7eWS!cnyYoaXwbkd_lCH2p5CCZ_PfLfy84MTWSGa0AmnpotPXn1C6JwSvE5W6ydUWlCa_0YvCINcSnv5BdBrfKzDiZqkcglM$
Huh, I think I read that issue at one point. It's probably what made me
use the "eventual consistency" term.
> Could you please retest with this PR?
> https://urldefense.us/v3/__https://github.com/epics-base/epics-base/pull/559__;!!G_uCfscf7eWS!cnyYoaXwbkd_lCH2p5CCZ_PfLfy84MTWSGa0AmnpotPXn1C6JwSvE5W6ydUWlCa_0YvCINcSnv5BdBrfKzDijS6xbIs$
It will take a while for me to be able to test it; I will need either a
machine shift in order to have more samples, or to figure out exactly
how to reproduce the error. I'm glad there is a PR to test though :)
Will keep you updated when I have news!
Érico
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Calc record with two CP input links ending up in inconsistent state Érico Nogueira Rolim via Tech-talk
Re: Calc record with two CP input links ending up in inconsistent state Michael Davidsaver via Tech-talk
Prev: Re: StreamDevice Checksum formatting bug Zimoch Dirk via Tech-talk
Next: Re: Using NDPluginGather to collect NDArrays from multiple detectors? Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Re: Calc record with two CP input links ending up in inconsistent state Michael Davidsaver via Tech-talk
Next: Using NDPluginGather to collect NDArrays from multiple detectors? Jörn Dreyer via Tech-talk
