On 21/02/2025 13:36, Gabriele Santambrogio via Tech-talk wrote:
Hi Gabriele!
If you wish to force processing from records in the "input" IOCs, you could have their FLNK fields set to "<your_calcout_record>.PROC CA", as documented in [1]. However, that leads to very undesirable coupling between IOCs (since they have to be aware of every IOC which depends on their PVs), so I'd say that the best course of action is using "<input_pv> CP" in your INPx fields, which mean the calcout record will be processed every time a monitor event from any of the input links arrives [2].
Cheers, Érico
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente. Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
ANJ, 21 Feb 2025 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
