Hi Patrik, As Maren points out, UKIRT and Keck may have been the first Telescopes using EPICS 3.12-ish(?) in the 90's. I recall William Lupton (Keck) and Nick Rees(UKIRT,JCMT) spearheaded the initiative to bring it to the Astronomy community. This was later supported by Maren, Allan Honey (drvSerial/drvAscii) collaborating with Jeff Hill and later Kevin Tsubota (Keck). When the Gemini project started many of the RGO staff developed EPICS related work packages: VMIC-5588 Reflective Memory, PMAC1 support, AllenBradley PLC5, GenSub Record (Andy Foster, Andrew Johnson et al), Xycom 240/566 (now acquired by Acromag?). I believe Mary Fuka (JCMT) worked on the predecessor to EDD/DM called GDCT(spelling?). Does that sound right, Maren? In 2009, I looked at Eric Norum's work bringing RTEMS 4.x to EPICS on PPC targets. At the time Gemini had its standard control as the mvme167 (68k) and the mvme2700 (MPC75). With Till Strauman (SLAC at the time) and Eric's help, I got the 2700 building for RTEMS 4.9.2 and it was accepted in EPICS 3.13 circa 2009. Gemini has since phased out the 167's and the 2700 is the ubiquitous Gemini controller. The 2700 now supports RTEMS 6.1 and development branches EPICS 7. Aloha, -Matt On Sun, Feb 23, 2025 at 1:13 AM Foster, Andrew (Observatory Science, RAL, TEC) via Tech-talk <tech-talk at aps.anl.gov> wrote:
ANJ, 25 Feb 2025 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
