1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: Image Acquisition Issue with AreaDetector/ADAravis
To: SuYin Grass Wang <[email protected]>
Date: Wed, 12 Mar 2025 05:07:03 +0000
Hi Grass,
Can you send a screenshot of the OPI screen when using the USB camera?
Sent from my iPhone
On Mar 11, 2025, at 5:56 PM, Wang, SuYin Grass via Tech-talk <[email protected]> wrote:
I am using AreaDetector and ADAravis to collect images.
The issue arises when I attempt to set
$(P)cam1:Acquire parameter to Acquire (1)
While  $(P)cam1:AcquireBusy changes to Acquiring (1),
$(P)cam1:DetectorState_RBV remains Idle (0),
and $(P)cam1:NumImagesCounter_RBV does not increase.
This behavior suggests that the image acquisition process is not proceeding as expected.
 I tested it with two different camera on a RHEL8 system, and got  the same problem.
The setups I am working with are as follows:
  1. arv-fake-gv-camera-0.8: This module creates a simulated camera at the local IP address 127.0.0.1.
  2. USB Camera Grasshopper3 GS3-U3-23S6M: This camera is connected via USB, and its firmware version is 2.30.3.00.
The software versions in use are:
  • SDK version: 0.8.20
  • Driver version: 2.2.1
  • ADCore version: 3.12.1
Interestingly, I have the same IOCs setup on multiple different workstations. Image collection works correctly on some workstations, but not on the other. There are no error messages in the IOCs that indicate what might be causing the issue.
I am seeking guidance on how to debug this problem, specifically to understand why the detector state does not change and why images are not being collected. Are there specific logs or diagnostic tools that you recommend using to identify the root cause of this issue?
Thank you!
Grass
Re: Image Acquisition Issue with AreaDetector/ADAravis Wang, SuYin Grass via Tech-talk
Prev: Re: Image Acquisition Issue with AreaDetector/ADAravis Jörn Dreyer via Tech-talk
Next: Substring replacement in Phoebus Alessandra Palazzo via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Next: Re: Image Acquisition Issue with AreaDetector/ADAravis Wang, SuYin Grass via Tech-talk
