1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: Structured PVs archiving and archived data retrieval problem
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 18 Mar 2025 10:26:57 +0000
Hi Ales,
  How complete is support for structured PVs in EPICS archiver appliance and aaclient tools (more details below)?
Archiver Appliance 1.1.0 had support for storing all pvAccess structures and some minimal retrieval in json. Archiver Appliance 2.0.5+ has support for storing all pvAccess structures and I believe complete retrieval with json.
To fetch the data from the archiver using json you go to something like:
http://hostname:17668/retrieval/data/getData.json?pv=pvName&from=2025-03-18T08:57:20.000Z&to=2025-03-18T09:57:22.734Z&fetchLatestMetadata=true
I think the postprocessors that should work are:
  • lastSample
  • firstSample
  • count
  • ncount
I agree with Michael that I don’t think any client has support for these structures, but it should be possible to add support. The data is stored as the pvAccess structure then the data itself, so to unpack the data is quite easy. The Archiver uses https://github.com/archiver-appliance/epicsarchiverap/blob/master/src/main/org/epics/archiverappliance/data/ByteBufSampleValue.java to convert the structure to json.
Maybe I’ll add it to py-epicsarchiver….
But I agree with Michael for NTTable its best to split up and make a pv for each array to be archived, as generally it works better with all the tools.
In terms of alternatives the Archiver Appliance, I would like to ask if you want a new feature or improvement to the Archiver Appliance to please open tickets! https://github.com/archiver-appliance/epicsarchiverap/issues And or support more development! I think adding support for more Normative Types makes sense, but its good to get a ticket to follow up on testing etc.
But to be fair when I did a review of alternatives I found:
Hope that helps,
Sky
Re: Structured PVs archiving and archived data retrieval problem Aleš Kete via Tech-talk
Prev: Re: Structured PVs archiving and archived data retrieval problem Michael Davidsaver via Tech-talk
Next: RE: Thermo Fischer FHT 6020 Radiation Monitor Baker, Keith (DLSLtd, RAL, LSCI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Prev: Re: Structured PVs archiving and archived data retrieval problem Aleš Kete via Tech-talk
Next: Re: Structured PVs archiving and archived data retrieval problem Aleš Kete via Tech-talk
