1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: RE: Thermo Fischer FHT 6020 Radiation Monitor
From: "Pearson, Matthew via Tech-talk" <[email protected]>
To: "Baker, Keith (DLSLtd,RAL,LSCI)" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 18 Mar 2025 17:50:20 +0000
Hi Keith,
If standard EPICS/network security practices are deemed insufficient to prevent remote setpoint or configuration changes, one option is to add a mailbox PLC to re-transmit the desired data to monitor.
Another option is to not use the serial comms and only connect up the analog or discrete I/O, if they contain sufficient information. Then you can use an ethernet connected unit with analog and digital inputs.
Cheers,
Matt
From: Tech-talk <[email protected]> On Behalf Of Baker, Keith (DLSLtd, RAL, LSCI) via Tech-talk
Sent: Tuesday, March 18, 2025 12:15 PM
To: [email protected]
Subject: [EXTERNAL] RE: Thermo Fischer FHT 6020 Radiation Monitor
Sorry, I was not at work yesterday, so have just caught up with all the responses and thought it best to reply to all in one message. Steve – yes, I’d be happy to receive another example database and protocol file. A Phoebus screen
Steve – yes, I’d be happy to receive another example database and protocol file. A Phoebus screen could be useful too.
Matthew, Martin – I anticipate using a Moxa terminal server as well, but you’ve highlighted security issues and options I need to consider. As you say, these are essential safety devices so any remote reconfiguration should be prevented or strictly controlled.
Martin – some more information on the RS232 device you have between the Moxa and FHT6020 would be useful. We’d aim to use RS485 as we’d prefer a long cable run from the Moxa to the device.
Regarding the Berthold, when I last looked at this, there was no EPICS support or any information I could find about how to communicate with this unit, so didn’t explore any further.
As for vibration, I’m not expecting any such issue with our installations mostly on concrete walls. Where are yours installed that exposes them to enough vibration to cause a problem?
Thanks to everyone else who posted comments or other example files which I have now downloaded and busy looking through. It seems people have taken a variety of approaches depending on their needs and I’m not sure which is the best match for us yet.
When I’ve played with our demo unit for a while I’ll post some feedback.
Keith
Sent: 17 March 2025 13:40
To: [email protected]; Baker, Keith (DLSLtd,RAL,LSCI) <[email protected]>
Subject: Re: Thermo Fischer FHT 6020 Radiation Monitor
You don't often get email from [email protected]. Learn why this is important
Hi Kieth,
Here is the link to the github repository:
The most interesting files are probably these:
Also, for the rest of the list, I had replied to Kieth last Friday but accidentally only replied to him.  Below is my original message from last Friday.
Hello Kieth,
We use these monitors at APS, and I have a streamdevice based IOC that I will post to github later today (US time).  I'll follow up with a link once available.
Note that our EPICs support is limited to readbacks only, as we considered it a safety issue to change the device configuration remotely.
Our screens are MEDM based, but probably could be converted to CSS without much difficulty.
We have our radiation monitors hooked up via the RS232 port to a moxa, which acts as a bridge to the network and EPICs.
Implementing EPICs communication support went relatively smoothly.  Outside of epics, we had some issues with vibrations affecting the readings, so you might consider testing with vibrations similar to your deployment environment.
I'll send the code link later.
Brendan Chandler
Brendan Chandler
From: Tech-talk <[email protected]> on behalf of Baker, Keith (DLSLtd, RAL, LSCI) via Tech-talk <[email protected]>
Sent: Friday, March 14, 2025 06:14
To: [email protected] <[email protected]>
Subject: Thermo Fischer FHT 6020 Radiation Monitor
Hello,
I have posted a few questions here in recent years asking about Radiation Monitors and had lots of helpful replies.
We are finally about to borrow a Thermo Fischer FHT 6020 for evaluation, so I would like to get an example EPICS IOC running.
I believe these monitors are in use or have been tested at ISIS, SLAC and Australia, perhaps elsewhere, so I was wondering who had the most up to date or complete driver they could share with me, please?
I found an asyn driver in SLACs EPICS repository and edl files. Is this my best choice to start with?
Does anybody use StreamDevice? (Brendan Chandler at APS mentioned this a few years ago.)
Has anybody created CSS opi files? (I could try running an eld->opi converter as a starting point.)
The monitor only seems to have an RS232 port, so I was wondering how different sites connect with this? Perhaps a local IOC with serial port, an RS232->RS485 adapter for more remote connections, or a local terminal server?
We don’t need to daisy chain the monitors. We’ll have dedicated wiring and IOC for each.
Any recommendations appreciated.
Thanks.
Keith Baker
Diamond Light Source
This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail. Any opinions expressed within this e-mail are those of the individual and not necessarily of Diamond Light Source Ltd.
Diamond Light Source Limited (company no. 4375679). Registered in England and Wales with its registered office at Diamond House, Harwell Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom.
Thermo Fischer FHT 6020 Radiation Monitor Baker, Keith (DLSLtd, RAL, LSCI) via Tech-talk
Re: Thermo Fischer FHT 6020 Radiation Monitor Chandler, Brendan via Tech-talk
RE: Thermo Fischer FHT 6020 Radiation Monitor Baker, Keith (DLSLtd, RAL, LSCI) via Tech-talk
Prev: Re: Thermo Fischer FHT 6020 Radiation Monitor Smith, Martin via Tech-talk
Next: Re: Thermo Fischer FHT 6020 Radiation Monitor Chandler, Brendan via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: RE: [External] RE: Thermo Fischer FHT 6020 Radiation Monitor Leblanc, Gregory via Tech-talk
Next: Channel Access performance with RTEMS on MVME5500 Wells, Alex (DLSLtd,RAL,LSCI) via Tech-talk
