Hello Alex,
This reminds me a little of a priority problem I noticed when we switched to POSIX_API.
There is still a confusion in RTEMS with the assignment of POSIX-Prios and RTEMS-Prios.
POSIX_Init is started with prio 2. This means the second highest priority after RTEMS, but with Posix it is a low priority.
That's why it looks like this in rtems_init.c at the moment:
void *
POSIX_Init ( void *argument __attribute__((unused)))
int result;
char *argv[3] = { NULL, NULL, NULL };
rtems_status_code sc;
struct timespec now;
char timeBuff[100];
initConsole ();
* Explain why we're here
logReset();
* If RTEMS is used with the POSIX API, the init task
* 'POSIX_Init()' is unfortunately given the priority '2'. This
* corresponds to the second lowest POSIX prio (RTEMS pthread
* prio 253). This task shoud have IOCsh prio.
pthread_attr_t attr;
struct sched_param param;
int policy;
sc = pthread_attr_init(&attr);
assert(sc == RTEMS_SUCCESSFUL);
sc = pthread_attr_getschedpolicy(&attr, &policy);
param.sched_priority = (sched_get_priority_max(policy)
- sched_get_priority_min(policy))
* epicsThreadPriorityIocsh / 100;
sc = pthread_setschedparam(pthread_self(), policy, ¶m);
Can you check with which priority the threads are really running?
On the RTEMS shell with the command ‘pthread’, ’task’ (and ‘irq’):
I use an ‘RTEMS-shell-wrapper’ from Michael on EPICS
MVME6100, RTEMS6 wiht legacy-stack:
IOC1> rt pthread
ID NAME SHED PRI STATE MODES EVENTS WAITINFO
0b010001 _main_ UPD 24 READY P:T:nA NONE
0b010002 scan-0.5 UPD 93 SEM P:T:nA NONE
0b010003 osdNTP_Runner UPD 27 SYSEV P:T:nA NONE
0b010004 taskwd UPD 229 SEM P:T:nA NONE
0b010005 osdNTP_Monitor UPD 128 SEM P:T:nA NONE
0b010006 NTPTimeSync UPD 27 SEM P:T:nA NONE
0b010007 errlog UPD 229 SEM P:T:nA NONE
0b010008 UPD 27 SEM P:T:nA NONE
0b010009 timerQueue UPD 103 SEM P:T:nA NONE
0b01000a timerQueue UPD 103 SEM P:T:nA NONE
0b01000b CAS-event UPD 206 SEM P:T:nA NONE
0b01000c awgport1 update UPD 100 SEM P:T:nA NONE
0b01000d CAS-client UPD 204 SYSEV P:T:nA NONE
0b01000e awgport2 update UPD 100 SEM P:T:nA NONE
0b01000f timerQueue UPD 77 SEM P:T:nA NONE
0b010010 cbLow UPD 105 SEM P:T:nA NONE
0b010011 cbMedium UPD 93 SEM P:T:nA NONE
0b010012 cbHigh UPD 75 SEM P:T:nA NONE
0b010013 dbCaLink UPD 128 SEM P:T:nA NONE
0b010014 PVAL UPD 128 SEM P:T:nA NONE
0b010015 timerQueue UPD 108 SEM P:T:nA NONE
0b010016 PDB-event UPD 206 SEM P:T:nA NONE
0b010017 pvAccess-client UPD 166 SEM P:T:nA NONE
0b010018 UDP-rx 0.0.0.0: UPD 128 SYSEV P:T:nA NONE
0b010019 UDP-rx 10.0.0.2 UPD 128 SYSEV P:T:nA NONE
0b01001a UDP-rx 10.0.1.2 UPD 128 SYSEV P:T:nA NONE
0b01001b UDP-rx 224.0.0. UPD 128 SYSEV P:T:nA NONE
0b01001c scanOnce UPD 85 SEM P:T:nA NONE
0b01001d scan-10 UPD 103 SEM P:T:nA NONE
0b01001e scan-5 UPD 100 SEM P:T:nA NONE
0b01001f scan-2 UPD 98 SEM P:T:nA NONE
0b010020 scan-1 UPD 95 SEM P:T:nA NONE
0b010021 scan-0.2 UPD 90 SEM P:T:nA NONE
0b010022 scan-0.1 UPD 88 SEM P:T:nA NONE
0b010023 CAS-TCP UPD 209 SYSEV P:T:nA NONE
0b010024 CAS-UDP UPD 214 SYSEV P:T:nA NONE
0b010025 CAS-beacon UPD 211 TIME:IS P:T:nA NONE Nanosleep
0b010026 CAC-event UPD 125 SEM P:T:nA NONE
0b010027 reccaster UPD 128 SYSEV P:T:nA NONE
0b010028 PVAS timers UPD 191 SEM P:T:nA NONE
0b010029 TCP-acceptor UPD 128 SYSEV P:T:nA NONE
0b01002a UDP-rx 0.0.0.0: UPD 128 SYSEV P:T:nA NONE
0b01002b UDP-rx 10.0.0.2 UPD 128 SYSEV P:T:nA NONE
0b01002c UDP-rx 10.0.1.2 UPD 128 SYSEV P:T:nA NONE
0b01002d UDP-rx 224.0.0. UPD 128 SYSEV P:T:nA NONE
0b01002e CAS-event UPD 206 SEM P:T:nA NONE
0b01002f CAS-client UPD 204 SYSEV P:T:nA NONE
0b010032 save_restore UPD 204 MSG P:T:nA NONE 1b010001
0b010033 CAC-event UPD 201 SEM P:T:nA NONE
0b010034 CAS-event UPD 206 SEM P:T:nA NONE
0b010035 CAS-client UPD 204 SYSEV P:T:nA NONE
0b010036 CAS-event UPD 206 SEM P:T:nA NONE
0b010037 CAS-client UPD 204 SYSEV P:T:nA NONE
0b010038 CAS-event UPD 206 SEM P:T:nA NONE
0b010039 CAS-client UPD 204 SYSEV P:T:nA NONE
0b01003a CAS-event UPD 206 SEM P:T:nA NONE
0b01003b CAS-client UPD 204 SYSEV P:T:nA NONE
0b01003d CAS-event UPD 206 SEM P:T:nA NONE
0b01003e CAS-event UPD 206 SEM P:T:nA NONE
0b01003f CAS-client UPD 204 SYSEV P:T:nA NONE
0b010040 CAS-event UPD 206 SEM P:T:nA NONE
0b010041 CAS-client UPD 204 SYSEV P:T:nA NONE
0b010042 CAS-event UPD 206 SEM P:T:nA NONE
0b010043 CAS-client UPD 204 SYSEV P:T:nA NONE
0b010044 CAS-event UPD 206 SEM P:T:nA NONE
0b010045 CAS-client UPD 204 SYSEV P:T:nA NONE
0b010046 CAS-event UPD 206 SEM P:T:nA NONE
0b010047 CAS-client UPD 204 SYSEV P:T:nA NONE
0b010048 CAS-event UPD 166 SEM P:T:nA NONE
0b010049 CAS-client UPD 163 SYSEV P:T:nA NONE
0b01004a CAS-event UPD 166 SEM P:T:nA NONE
0b01004b CAS-client UPD 163 SYSEV P:T:nA NONE
0b010050 CAS-client UPD 204 SYSEV P:T:nA NONE
0b010051 CAS-event UPD 206 SEM P:T:nA NONE
0b010052 CAS-client UPD 204 SYSEV P:T:nA NONE
0b010053 CAS-event UPD 206 SEM P:T:nA NONE
0b010054 CAS-client UPD 204 SYSEV P:T:nA NONE
IOC1>
IOC1> rt task
0a010001 _BSD UPD 10 SYSEV P:T:nA NONE
0a010002 _BSD UPD 10 SYSEV P:T:nA NONE
0a010003 RPCd UPD 10 EV P:T:nA NONE
0a010004 TNTa UPD 100 SYSEV P:T:nA NONE
0a010005 TNTb UPD 100 SYSEV P:T:nA NONE
0a010006 TNTc UPD 100 SYSEV P:T:nA NONE
0a010007 TNTd UPD 100 SYSEV P:T:nA NONE
0a010008 TNTe UPD 100 SYSEV P:T:nA NONE
0a010009 TNTD UPD 100 SYSEV P:T:nA NONE
IOC1> rt irq
INTERRUPT INFORMATION
VECTOR | INFO | OPTIONS | HANDLER | ARGUMENT
( Example on a beaglebone black with libbsd-stack )
beaglebone> rt pthread
0b010001 _main_ UPD 25 READY P:T:nA 00002000
0b010003 errlog UPD 229 SEM P:T:nA NONE
0b010004 osdNTP_Runner UPD 27 READY P:T:nA NONE
0b010007 taskwd UPD 229 SEM P:T:nA NONE
0b010009 timerQueue UPD 77 SEM P:T:nA NONE
0b01000a cbLow UPD 105 SEM P:T:nA NONE
0b01000b cbMedium UPD 93 SEM P:T:nA NONE
0b01000c cbHigh UPD 75 SEM P:T:nA NONE
0b01000d dbCaLink UPD 128 SEM P:T:nA NONE
0b01000e scanOnce UPD 85 SEM P:T:nA NONE
0b01000f scan-10 UPD 103 SEM P:T:nA NONE
0b010010 scan-5 UPD 100 SEM P:T:nA NONE
0b010011 scan-2 UPD 98 SEM P:T:nA NONE
0b010012 scan-1 UPD 95 READY P:T:nA NONE
0b010013 scan-0.5 UPD 93 SEM P:T:nA NONE
0b010014 scan-0.2 UPD 90 READY P:T:nA NONE
0b010015 scan-0.1 UPD 88 READY P:T:nA NONE
0b010016 CAS-TCP UPD 209 WK P:T:nA NONE accept
0b010017 CAS-UDP UPD 214 WK P:T:nA NONE sbwait
0b010018 CAS-beacon UPD 211 TIME:IS P:T:nA NONE Nanosleep
beaglebone> rt task
0a010001 TIME UPD 98 READY P:T:nA NONE
0a010002 IRQS UPD 96 READY P:T:nA NONE
0a010003 _BSD swi6: Giant tas UPD 100 EV P:T:nA NONE
0a010004 _BSD config_0 UPD 100 WK P:T:nA NONE -
0a010005 _BSD kqueue_ctx task UPD 100 WK P:T:nA NONE -
0a010006 _BSD swi6: task queu UPD 100 EV P:T:nA NONE
0a010007 _BSD swi5: fast task UPD 100 EV P:T:nA NONE
0a010008 _BSD thread taskq UPD 100 WK P:T:nA NONE -
0a010009 _BSD swi1: netisr 0 UPD 100 EV P:T:nA NONE
0a01000a _BSD usbus0 UPD 100 WK P:T:nA NONE -
0a01000b _BSD usbus0 UPD 100 WK P:T:nA NONE -
0a01000c _BSD usbus0 UPD 100 WK P:T:nA NONE -
0a01000d _BSD usbus0 UPD 100 WK P:T:nA NONE -
0a01000e _BSD usbus0 UPD 100 WK P:T:nA NONE -
0a01000f _BSD usbus1 UPD 100 WK P:T:nA NONE -
0a010010 _BSD usbus1 UPD 100 WK P:T:nA NONE -
0a010011 _BSD usbus1 UPD 100 WK P:T:nA NONE -
0a010012 _BSD usbus1 UPD 100 WK P:T:nA NONE -
0a010013 _BSD usbus1 UPD 100 WK P:T:nA NONE -
0a010014 _BSD bufdaemon UPD 100 READY P:T:nA NONE
0a010015 _BSD vnlru UPD 100 WK P:T:nA NONE vlruwt
0a010016 _BSD syncer UPD 100 WK P:T:nA NONE syncer
0a010017 _BSD softirq_0 UPD 100 WK P:T:nA NONE -
0a010018 DHCP UPD 254 WK P:T:nA NONE select
0a010019 _BSD bufspacedaemon- UPD 100 READY P:T:nA NONE
0a01001a _BSD nfscl UPD 100 WK P:T:nA NONE nfscl
0a01001b TNTa UPD 100 SYSEV P:T:nA NONE
0a01001c TNTb UPD 100 SYSEV P:T:nA NONE
0a01001d TNTc UPD 100 SYSEV P:T:nA NONE
0a01001e TNTd UPD 100 SYSEV P:T:nA NONE
0a01001f TNTe UPD 100 SYSEV P:T:nA NONE
0a010020 TNTD UPD 100 WK P:T:nA NONE accept
beaglebone> rt irq
18 | IRQS | SHARED | 0x803d6100 | 0x8072b4a8
19 | IRQS | SHARED | 0x803d6100 | 0x80757410
28 | IRQS | SHARED | 0x803d6100 | 0x807287f8
30 | BBB_I2C | UNIQUE | 0x803d6b6c | 0x8065e5c8
40 | IRQS | SHARED | 0x803d6100 | 0x8078a4d0
41 | IRQS | SHARED | 0x803d6100 | 0x8078a538
42 | IRQS | SHARED | 0x803d6100 | 0x8078a5a0
43 | IRQS | SHARED | 0x803d6100 | 0x8078a608
64 | IRQS | SHARED | 0x803d6100 | 0x80727a90
67 | Clock | UNIQUE | 0x803d381c | 0x0
70 | BBB_I2C | UNIQUE | 0x803d6b6c | 0x8065e4f0
72 | NS16550 | SHARED | 0x803d4db8 | 0x0
Heinz
Fritz-Haber-Institut | Phone: (+49 30) 8413-4270
Heinz Junkes | Fax (G3+G4): (+49 30) 8413-5900
Faradayweg 4-6 | VC: https://zoom.fhi.berlin/junkes
D - 14195 Berlin | E-Mail: [email protected]
“Sorry I’m a bit late, had a terrible time…
All sort of things cropping up at the last moment. Uh, how are we for time?”
—Zarquon's address to Milliways
> On 18. Mar 2025, at 17:41, Wells, Alex (DLSLtd,RAL,LSCI) via Tech-talk <[email protected]> wrote:
> Hi Michael,
> I can confirm the CPU use goes to zero when the network cable is unplugged. We do image and file loading over the network, but once all that has completed I can pull the cable out and observe no CPU use by that thread. The system also becomes fully responsive on the console, which correlates the significant drop in CPU use.
> I have only tested RTEMS 5.1, which I believe is using the "legacy" IP stack. In a few months, during the next shutdown, I may be able to test RTEMS6 but we have no particular reason to expect the newer stack to work better, as the MVME5500 is 30 years old now so the new stack is unlikely to be optimized for its use case.
> Thanks,
> Alex WellsFrom: Michael Davidsaver <[email protected]>
> Sent: Friday, March 14, 2025 4:39 PM
> To: Wells, Alex (DLSLtd,RAL,LSCI) <[email protected]>
> Cc: [email protected] <[email protected]>
> Subject: Re: Channel Access performance with RTEMS on MVME5500
> Hello Alex,
> As a quick test, have you tried unplugging the ethernet cable to ensure that
> the reported CPU usage for CAS-UDP goes to zero?
> Also, which RTEMS version(s) have you tested?
> Is this the RTEMS "legacy" IP stack, or the newer libbsd stack?
> On 3/14/25 06:30, Wells, Alex (DLSLtd,RAL,LSCI) via Tech-talk wrote:
> > Hello Tech Talk,
> > I'm in the process of moving some VME crates from VxWorks to RTEMS. This also moves from EPICS 3.14.12.7 to EPICS 7.0.7. I'm seeing significant amounts of CPU activity in the "CAS-UDP" thread, and was hoping someone may be able to explain it.
> > Averaged over time, RTEMS reports that the CAS-UDP thread is using ~40% of the CPU. This persists even when removing all the processing from all records (thus removing all other possible CPU use). During initialization of the IOC, and for several minutes after initialization finished, I see 80%+ CPU usage on the IOC overall, mostly on this one thread, and it makes the overall IOC very unresponsive. This same behaviour also happens intermittently during operation, where even record processing seems to become delayed due to Channel Access processing - for example the devIocStats Heartbeat record that should just increase by 1 per second sometimes pauses for multiple seconds.
> > The network the IOC is on is requesting a fair number of PVs from this IOC. CaSnooper shows between 20 and 40 requests per second to PV(s) on this IOC. Approximately 500 PVs are being requested from the IOC. These requests are spread across approximately 30 separate clients.
> > When I compare this to the VxWorks version, running on the same hardware and network, I see less almost 0% CPU usage on the CAS-UDP thread, and no record processing hitches. The CPU also idles significantly lower than for RTEMS.
> > Our current theory is that the RTEMS network stack for UDP processing is much less efficient, and is struggling with the volume of requests. Is anyone able to confirm/deny this, and does anyone have any potential workarounds?
> > Thanks,
> > Alex Wells
> > Diamond Light Source
> > This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail. Any opinions expressed within this e-mail are those of the individual and not necessarily of Diamond Light Source Ltd.
> > Diamond Light Source Ltd. cannot guarantee that this e-mail or any attachments are free from viruses and we cannot accept liability for any damage which you may sustain as a result of software viruses which may be transmitted in or with the message.
> > Diamond Light Source Limited (company no. 4375679). Registered in England and Wales with its registered office at Diamond House, Harwell Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom.
smime.p7s
Description: S/MIME cryptographic signature
- Re: Channel Access performance with RTEMS on MVME5500 Wells, Alex (DLSLtd,RAL,LSCI) via Tech-talk
- Channel Access performance with RTEMS on MVME5500 Wells, Alex (DLSLtd,RAL,LSCI) via Tech-talk
- Re: Channel Access performance with RTEMS on MVME5500 Michael Davidsaver via Tech-talk
Re: Converting Application using sumo Johnson, Andrew N. via Tech-talk
<2025>
2026
Re: Channel Access performance with RTEMS on MVME5500 Johnson, Andrew N. via Tech-talk
<2025>
2026
