You could also use the c++ mysql connector from e.g. an aSub record
Freddie
> -----Original Message-----
> From: Akeroyd, Freddie (STFC,RAL,ISIS)
> Sent: 25 March 2025 12:38
> To: 'Zimoch Dirk' <[email protected]>; Heinz Junkes <junkes@fhi-
> berlin.mpg.de>
> Cc: EPICS Tech Talk <[email protected]>
> Subject: RE: Using Streamdevice to run SQL Query ?
> Hi Heinz,
> We've done this in python using pcaspy and the python mysql connector
> Regards,
> Freddie
> > From: Tech-talk <[email protected]> On Behalf Of Zimoch
> > Dirk via Tech-talk
> > Sent: 25 March 2025 11:04
> > To: Heinz Junkes <[email protected]>
> > Subject: Re: Using Streamdevice to run SQL Query ?
> > Hello Heinz,
> > Does your sql database have a TCP socket to write the queries to?
> > Maybe a web interface?
> > If not, can you use for example ncat to pass queries from a TCP socket
> > to stdin of a sql command line interface?
> > Once you have a TCP port that accepts sql queries, it should be
> > possible to use it with StreamDevice.
> > Dirk
> > > On 25 Mar 2025, at 07:24, Heinz Junkes via Tech-talk <tech-
> > [email protected]> wrote:
> > > Good morning,
> > > We are currently having an EPICS training week. A participant asked
> > > if it is possible to create PVs that can make an SQL query against a
> > > mySQL
> > database.
> > > The measurement data is stored by a foreign system in a database.
> > > The idea is to provide the values in the database as EPICS-PVs for
> > caput/caget.
> > > Has anyone done this before?
> > > Thanks Heinz
- Using Streamdevice to run SQL Query ? Heinz Junkes via Tech-talk
- Re: Using Streamdevice to run SQL Query ? Zimoch Dirk via Tech-talk
- RE: Using Streamdevice to run SQL Query ? Freddie Akeroyd - STFC UKRI via Tech-talk
Phoebus Question Rebecca Harding - STFC UKRI via Tech-talk
<2025>
2026
<2025>
2026
