1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: Connect to IOC in container from another host in different network, via CA Gateway
From: "Knap, Giles \(DLSLtd,RAL,LSCI\) via Tech-talk" <[email protected]>
To: "Gonzalez, Jose Carlos" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 28 Mar 2025 22:42:31 +0000
I should have mentioned that you can't do the same with PVAccess. UDP traffic will not get through to the container - using EPICS_PVA_NAME_SERVERS to point at the container host does work as it uses TCP. This can be a list of PVA servers but would not scale well if you had many PVA servers.
The alternative that does work for PVA and CA is to put all your IOCs in the host network and then you don't need any gateways.
Sent: 28 March 2025 16:28
To: Knap, Giles (DLSLtd,RAL,LSCI) <[email protected]>; [email protected] <[email protected]>
Great, thanks a lot!
I will have a look and let you know. BTW, I got both mails, also the one with the image 😊
Cheers,
J C
From: Knap, Giles (DLSLtd,RAL,LSCI) <[email protected]>
Sent: 28 March 2025 15:57:59
To: [email protected]; Gonzalez, Jose Carlos
Hi Jose,
(resending without the image that was too big for techtalk!)
I usually make my simulation beamline in containers only accessible from the local machine. However by binding the cagateway ports to all interfaces I can also make the PVs accessible to the subnet.
giles
This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail. Any opinions expressed within this e-mail are those of the individual and not necessarily of Diamond Light Source Ltd.
Diamond Light Source Limited (company no. 4375679). Registered in England and Wales with its registered office at Diamond House, Harwell Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom.
Connect to IOC in container from another host in different network, via CA Gateway Gonzalez, Jose Carlos via Tech-talk
Re: Connect to IOC in container from another host in different network, via CA Gateway Knap, Giles (DLSLtd,RAL,LSCI) via Tech-talk
Re: Connect to IOC in container from another host in different network, via CA Gateway Gonzalez, Jose Carlos via Tech-talk
Prev: Re: alarm handling in EPICS 7 Maren Purves via Tech-talk
Next: Re: alarm handling in EPICS 7 Maren Purves via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Prev: Re: Connect to IOC in container from another host in different network, via CA Gateway Gonzalez, Jose Carlos via Tech-talk
Next: alarm handling in EPICS 7 Pedro Gigoux via Tech-talk
