1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Subject: Phoebus is unable to see PVs inside docker containers
From: "Srinivas, Dhruv via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 3 Apr 2025 17:51:20 +0000
Hello,
I’m installing several IOCs on a new machine. If I run it locally on the machine itself, then Phoebus is able to see the PVs in said IOCs. However, when I place the IOCs into a docker image then run it using the following command, Phoebus can only see one IOC at a time:
“docker run -dit --network=host --name=<name> <image_name>”
So far I’ve attempted to set auto_addr_list, addr_list, and name_servers in the Phoebus settings.ini file. So far I’ve been able to confirm that my setting changes did take effect, but the problem persists.
Does anyone happen to know how to resolve this issue?
Sincerely,
Dhruv Srinivas
srinivas1 at llnl.gov
Re: Phoebus is unable to see PVs inside docker containers Jörn Dreyer via Tech-talk
Prev: Re: Stream2 support in ADEiger Yendell, Gary (DLSLtd, RAL, LSCI) via Tech-talk
Next: Re: RFC: add a mechanism to call epicsExit when signals are received Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Prev: Re: RFC: add a mechanism to call epicsExit when signals are received Érico Nogueira Rolim via Tech-talk
Next: Re: Phoebus is unable to see PVs inside docker containers Jörn Dreyer via Tech-talk
ANJ, 04 Apr 2025 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
