Hi, I am encountering a critical issue with PV connectivity while using the Phoebus Alarm Server alongside a local EPICS IOC. Both the EPICS IOC and phoebus run on the local device.
EPICS IOC Verification: Target PV: TEST:CAT1/test:ai1 EPICS_CA_SERVER_PORT=6310. The IOC can run normally and obtain the PV value. I set the parameters in the setting.ini in alarm-server as follows: In alarm-server/settings.ini :org.phoebus.pv.ca/addr_list= 127.0.0.1:6310
org.phoebus.pv.ca/auto_addr_list=false When you run alarm-server, the following error message is displayed: 2025-04-07 20:26:10 WARNING [org.phoebus.applications.alarm] /Accelerator/xiaomin/TEST:CAT1/test:ai1 connection timed out When running phoebus, the interface is in the attachment. Any patches or workarounds for this issue? I am happy to provide additional logs or configuration files if needed. Thank you for your time and assistance! Best regards, xiaomin liuxiaomin at sari.ac.cn Attachment:
ANJ, 08 Apr 2025 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
