1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: [Ext] Help with motorNewport config
From: "Blomley, Edmund \(IBPT\) via Tech-talk" <[email protected]>
Date: Thu, 10 Apr 2025 07:44:29 +0000
Hey Mark,
I think that logic is incorrect.  If deferMoves is true then it does correctly just set the flag and return.  However, deferMoves is false and movesDeferred_ is false (not currently in a deferred move state) then it sets moveDeferred_ = true and returns.  That is incorrect, it should simply return, it should not set movesDeferred_=true.
If the client is “well-behaved” it will only call this function with deferMoves=true when movesDeferred=false, and it will only call it with deferMoves=false and movesDeferred=true.  That could explain why this problem has not been previously noticed.  It appears that for some reason what you are doing is causing this function to be called a second time with deferMoves=false, when movesDeferred_ is already false.
I think the solution is to change this code to:
  if (deferMoves) {
    movesDeferred_ = true;
    return asynSuccess;
  if (!movesDeferred_) {
    return asynSuccess;
Sorry for the late response. I tried your patch, but it didn’t really seem to change much. Also I am not sure how our client could not be „well-behaved“, as we currently use the record itself and normal caput commands with epics base 7.0.6.
This is the record we use:
record(bo, "$(P)DeferMovement") {
    field(DESC, "Defer Moves")
    field(DTYP, "asynInt32")
    field(OUT, "@asyn($(PORT),$(ADDR),$(TIMEOUT=1))MOTOR_DEFER_MOVES")
    field(SCAN, "Passive")
    field(ZNAM, "Go")
    field(ONAM, "Defer")
    field(VAL, "0")
Are there some debug options I can switch on for the IOC to help me tracking down what is actually send from this particular record only?
Cheers
Eddy
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: [Ext] Help with motorNewport config Laurenz Rettig via Tech-talk
Re: [Ext] Help with motorNewport config Blomley, Edmund (IBPT) via Tech-talk
RE: [Ext] Help with motorNewport config Mark Rivers via Tech-talk
Prev: Re: Video camera for use in high magnetic field Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
Next: Re: [Ext] Help with motorNewport config Laurenz Rettig via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Prev: RE: [Ext] Help with motorNewport config Mark Rivers via Tech-talk
