1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: Re: write and read functions in asyn
To: 高振华 <[email protected]>
Date: Sat, 12 Apr 2025 16:46:26 +0000
  • Does the (* write) function in asynInt32.h inherit from the writeIt function in drvAsynSerialPort.c (when accessing a serial port)?
No, the drvAsynSerialPort driver does not implement the asynInt32 interface.
It implements the asynCommon inteface here.  All drivers must implement asynCommon:
It implements the asynOption interface here:
It implements the asynOctet interface here:
Those are the only interfaces that it implements.
This is a simple example driver that implements the asynInt32 interface:
Many drivers now use the asynPortDriver base class.  It greatly simplifies the code required to register and implement asyn interfaces.  This is the code:
This is the documentation:
This is a real driver for a simple device that implements the asynInt32 interface using asynPortDriver.
Sent: Saturday, April 12, 2025 6:39 AM
To: Mark Rivers <[email protected]>
Cc: [email protected] <[email protected]>
Hi Mark,
static asynStatus writeIt(void *drvPvt, asynUser *pasynUser, const char *data, size_t numchars,size_t *nbytesTransfered)
    ttyController_t *tty = (ttyController_t *)drvPvt;
    int thisWrite;
    int nleft = numchars;
    int timerStarted = 0;
    asynStatus status = asynSuccess;
    assert(tty);
Gao Zhenhua
-----原始邮件-----
发件人: "Mark Rivers" <[email protected]>
发送时间: 2025-04-11 11:23:41 (星期五)
收件人: "[email protected]" <[email protected]>, 高振华 <[email protected]>
主题: Re: write and read functions in asyn
Those functions are implemented by the asyn driver.  asynInt32.h defines the interface, but the implementation is done in each driver.
They are analogous to C++ pure virtual functions that each derived class must implement.
From: Tech-talk <[email protected]> on behalf of 高振华 via Tech-talk <[email protected]>
Sent: Thursday, April 10, 2025 8:46 PM
To: [email protected] <[email protected]>
Subject: write and read functions in asyn
Hi all,
I saw the prototype declarations for the write and read functions in this. h file(asyn/asyn/interfaces/asynInt32.h),
But I couldn't find the bodies of the write and read functions,
Does anyone know where it is?
typedef struct asynInt32 {
    asynStatus (*write)(void *drvPvt, asynUser *pasynUser, epicsInt32 value);
    asynStatus (*read)(void *drvPvt, asynUser *pasynUser, epicsInt32 *value);
    asynStatus (*getBounds)(void *drvPvt, asynUser *pasynUser,
                           epicsInt32 *low, epicsInt32 *high);
    asynStatus (*registerInterruptUser)(void *drvPvt,asynUser *pasynUser,
                           interruptCallbackInt32 callback, void *userPvt,
                           void **registrarPvt);
    asynStatus (*cancelInterruptUser)(void *drvPvt, asynUser *pasynUser,
                           void *registrarPvt);
} asynInt32;
Gao Zhenhua
BSRF
Email:[email protected]
祝好!
高振华
电话:010-88235426
Re: Re: Re: write and read functions in asyn 高振华 via Tech-talk
Re: write and read functions in asyn Mark Rivers via Tech-talk
Prev: Re: Re: write and read functions in asyn 高振华 via Tech-talk
Next: Re: Re: Re: write and read functions in asyn 高振华 via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
