1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: devoms.css Accl epics ioc error
To: [email protected]
Date: Tue, 15 Apr 2025 21:45:48 +0900
Hello, we are controlling the motor as VME(MVME6100) and OMS maxv controller. we found an error information on EPICS IOC suddenly who used well before.
The motor moves, but it moves only a little when the client sends more commands. (ex. 10mm needs to be sent commands for 10mm movements more than 10 times to send)
This problem seems to be a problem that the controller does not recognize the pulse as the log message below repeats indefinitely.
error message -> "filename="../devOmsCom.cc" line number=324 Overriding invalid acceleration."
This error message repeats indefinitely.I still get an error even though I set the accl value to 2. It keeps happening even if I don't move the motor.
Do you happen to know the solution? I also checked if there are multiple pv's running through Cainfo.
[VxWorks Boot]:
boot device : geisc
unit number : 0
processor number : 0
host name : host
file name : /usr/local/epics/vxWorks
inet on ethernet (e) : 10.4.112.25:fffff000
inet on backplane (b): 0
startup script (s) : host:/usr/local/epics/synApps_5_8/support/motor-6-9/iocBoot/motor/st.cmd
Loading... 2729360
Starting at 0x100000...
tffsDevCreate failed.
Adding 7870 symbols for standalone.
]]]]]]]]]]] ]]]] ]]]]]]]]]] ]] ]]]] (R)
]]]]]]]]]]]]]]]]]]]]]]]]]]]]] Development System
]]]]]]]]]]]]]]]]]]]]]]]]]]] VxWorks 6.9
]]]]]]]]]]]]]]]]]]]]]]]]]] KERNEL: WIND version 2.13
]]]]]]]]]]]]]]]]]]]]]]]]] Copyright Wind River Systems, Inc., 1984-2013
CPU: Motorola MVME6100-0173 - MPC 7457. Processor #0.
Memory Size: 0x40000000 (1024Mb). BSP version 6.9/0.
cd "host:/usr/local/epics/synApps_5_8/support/motor-6-9/bin/vxWorks-ppc32"
value = 0 = 0x0
ld < NoAsynVx.munch.ori
value = 74434944 = 0x46fc980
rebootHookAdd(epicsExitCallAtExits)
value = 0 = 0x0
cd startup
value = 0 = 0x0
dbLoadDatabase("$(Top)/dbd/NoAsynVx.dbd")
value = 0 = 0x0
dbLoadDatabase("$(Top)/dbd/motorRecord.dbd")
value = 0 = 0x0
dbLoadDatabase("$(Top)/dbd/devOms.dbd")
value = 0 = 0x0
NoAsynVx_registerRecordDeviceDriver(pdbbase)
value = 0 = 0x0
dbLoadTemplate("motor2.substitutions")
value = 0 = 0x0
MAXvSetup(4, 16, 0x1000, 0, 4, 10)
value = 0 = 0x0
str = malloc(300);
New symbol "str" added to kernel symbol table.
str = 0x47561f0: value = 74799088 = 0x47557f0
strcpy str, "AA; LMH, H, H, H, H, H, H, H;"
strcat str, "AX LL PSE; AY LL PSE; AZ LL PSO; AT LL PSE; AU LH PSO; AV LH PSO; AR LL PSO; AS LL PSO;"
MAXvConfig(0, str)
value = 0 = 0x0
free(str)
value = 0 = 0x0
< save_restore.cmd
Autosave save_restore start
Debug-output level
save_restoreSet_Debug(0)
value = 0 = 0x0
iocInit
Starting iocInit
EPICS R3.15.4 $Date: Fri 2016-05-27 08:54:04 +0200$
EPICS Base built Jul 25 2016
iocInit: driver drvOmsPC68 not found
device support devOmsPC68 not found
value = 0 = 0x0
filename="../devOmsaCom.cc" line numberv=324
Overriding invealid acceleration.
Best & regards
baeg
RE: devoms.css Accl epics ioc error Mark Rivers via Tech-talk
Prev: RE: EPICS build problem Freddie Akeroyd - STFC UKRI via Tech-talk
Next: Teledyne RETIGA E7 John Dobbins via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Re: EPICS build problem Ralph Lange via Tech-talk
Next: RE: devoms.css Accl epics ioc error Mark Rivers via Tech-talk
